How 'tight' should Shock Heim Joints be? - Defender Source
Old March 26th, 2008, 02:11 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
I've got Fox shocks on the Defender as part of a Stage III suspension Kit from SG. When you grab a mounted shock by the body, and attempt to twist it, should it move very easily to the limit of the heim joint, or should it be fairly snug, requiring some effort to twist the shock body? Am I making any sense?
~Scott T.
'95 D-90 ST - AA Yellow
Old March 26th, 2008, 03:35 PM
fleabus's Avatar
fleabus
Dan
None :(
Makes perfect sense... it should move relatively freely... hence the purpose of the speherical bearing. I had one stick once when the bearing was shot.
On a related note... the upper eyelet of my fox shocks were knocking against the washers on the upper rear mounts (when the shock would twist) so I replaced the spherical bearings with poly bushings.
Sounds as a pound
-Dan
Old March 26th, 2008, 03:44 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Sounds as a pound
-Dan
Okay, sounds like the problem I have, and the noise is driving me nuts. Any more info on the poly bushing kits for the fox shocks?
~Scott T.
Old March 26th, 2008, 03:45 PM
fleabus's Avatar
fleabus
Dan
None :(
Yessir:
http://www.offroadwarehouse.com/prod...productID/3771
Old March 26th, 2008, 03:54 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Thanks for the link!
~Scott T.
ht
Pics of modded shock towers??? cbass Defender Technical Discussions 27 November 21st, 2008 08:52 PM
Adjustable Panhard Rod with Heim Joints RyanS Defender Technical Discussions 21 August 12th, 2005 08:33 PM
external front shock mounts? brianbonner Defender Technical Discussions 9 January 11th, 2005 05:06 PM
heim joint question erik d Defender Technical Discussions 1 November 7th, 2004 06:50 PM
Rancho 9005 shock DBZ2009 Defender Technical Discussions 6 December 13th, 2003 10:28 AM
