How The F Does This Happen? - Page 2 - Defender Source
Old June 6th, 2012, 09:58 AM
Wolf Fabrication's Avatar
Wolf Fabrication
Sterling Archer
'08 D3
Originally Posted by carlosz View Post
the inner axle housing, near where the swivel bolts onto the housing, does have a copper bushing to keep the pivot point of the cv joint from bouncing around and causing this issue, inspect for fitting and existence, also the inner tip of the spindle (stubby), where it bolts onto the axle will have the same bushing....all of this is to support the cv in a straight position.
This is a rear Salisbury - there in no bushing on the outter end of the axle tube. My stub axle does have the inner bushing in place, but I'll check for wear.
------ Follow up post added June 6th, 2012 10:00 AM ------
Originally Posted by ini88 View Post
Mine did this at the winter romp. There is a copper bushing (bearing) on the other side of the axle stub that need to be inserted. http://www.defendersource.com/forum/...&postcount=163
http://www.roversnorth.com/p-3890-be...90-rrover.aspx
They were used stub axles and did have the inner bushings, but I'll double-check their condition.
Semper Fi!
Old June 6th, 2012, 10:15 AM
The Dro
Dro
1988 Ninety
Originally Posted by o2batsea View Post
It was Pedro.
But we hatched this plan at the last HH, which you missed. So it's really all of us. Well, mainly Lavender. Yup it was all his idea. And Galpin. We just made Pedro do it. Lots of texting.
There. It's out there now and we can all just say we are sorry.
'K?
You couldn't keep it a secret... eh!
I mean... I was out of town and have alibis.
Old June 6th, 2012, 10:19 AM
carlosz's Avatar
carlosz
Carlos
sorry, saw the pic and read description but somehow did not register of what I saw with what I read... if it was bent the damage would not be around it, but it would be spotty... if it flexes thus causing warpage under load then a whole different issue has arisen.
remember the axle is a full floating unit so it is nothing but a driver, it is the stub which supports the weight so for it to show the damage shown ir would have to warp under load... loose axle damages the hub threads, leaks oil and pings when shifting, if using factory bolts they will shear as well... loose bearing as others have mention is a remote possibility but still possible.
Old June 6th, 2012, 10:28 AM
airbornrover's Avatar
airbornrover
William Skidmore
SIII 109 SW
Call up the KAM guys and see what info they have for your situation. Since they supply the military, am sure they have seen it before.
OMG....What just happen !!??? DucatiChick Defender Technical Discussions 11 January 1st, 2012 10:50 PM
Ignition switch jumping jellyfish Defender Technical Discussions 1 October 15th, 2009 11:50 PM
Oil Cooler Line Parts List Wolf Fabrication Defender Technical Discussions 30 November 7th, 2007 12:29 PM
Looking to trade for seats!!! Rangermeehan For Sale - Parts 13 October 17th, 2007 09:47 PM
How often does this happen? Willh Misc. Chit-Chat 15 July 12th, 2007 08:37 AM
