How repair door card buttons - Defender Source
Old August 31st, 2010, 10:12 PM
Talking How repair door card buttons
On the back of SW door cards, all the little plastic fir trees attach to the door card by the molded yellow plastic buttons (non-replaceable as far as I know). Inevitably, some of those buttons break, thereby preventing a fir tree from being attached to that point. This has continuously annoyed and plagued me. Well, I went out to the home improvement store (Lowes to be specific) with the mission to find a repair item to fix it, and I found one.
In the pictures below, my invented process is below.
  1. trim off remainder of damaged yellow button top
  2. drill a small hole right through center
  3. put a drop of super glue in the hole
  4. tap in a small tack nail in the hole until it is almost flush (about 1/8 inch above)
  5. problem solved
You can see the exact tac nail in the picture below. it is a perfect fit for the fir tree. the fir tree sits on it nice and snug.
You gotta love cheap solutions. I'm hoping that this will rank up there with the penny in the door trick.
ID:	30582   Click image for larger version
ID:	30584   Click image for larger version
Old September 1st, 2010, 12:58 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
I need to do this. Thanks for the tip!
Old September 1st, 2010, 02:28 PM
Chaucer
Will
93 110 | 97 90
Nice trick!
Old October 1st, 2010, 04:04 PM
Just tried this ... Brilliant solution!
Old April 19th, 2014, 12:12 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
What about using a sheet metal screw and grind the head before setting it in some super glue or epoxy ?
Your solution is faster but will they hold when you take the door card off ?
- Charles Eames
Old April 19th, 2014, 01:12 PM
Originally Posted by JFD View Post
What about using a sheet metal screw and grind the head before setting it in some super glue or epoxy ? Your solution is faster but will they hold when you take the door card off ?
Yes they hold.
Old April 19th, 2014, 05:02 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Yes they hold.
Did you change them all or just the broken ones?
- Charles Eames
Old April 19th, 2014, 06:10 PM
Just broken ones .. But I now have puma doors which don't have any broken fir trees.
Old April 20th, 2014, 04:03 PM
JFD's Avatar
JFD
Julien Dalbin
05 Tdi 90
Found a couple of alternatives:
* the head of a 5/32 x 3/8 aluminum rivet, I cut a few slots on the body for better grip
* #8 x 3/4 sheet metal screw with a grinded head
I have to change almost all on my door card, the rivet solution is faster than the
screw one but I think the screw will hold better.
- Charles Eames
door
RECO: Repair Manual for 95 SW reaper99999 Defender Technical Discussions 0 March 5th, 2006 05:07 AM
Door Panel Repair? boshea Defender Technical Discussions 3 January 17th, 2006 04:13 PM
Corrosion repair ideas mattarm Defender Technical Discussions 6 February 2nd, 2005 10:18 AM
how to repair hard top crack? chirider Defender Technical Discussions 8 December 14th, 2004 08:11 AM
Speedo repair artm Defender Technical Discussions 3 October 21st, 2004 08:33 PM
