How Often to Top Off Power Steering Fluid? - Defender Source
Old February 20th, 2014, 10:27 AM
Axel's Avatar
Axel
jack
1987 Defender 110 5-door
I assume it's normal to have to top off the power steering fluid in a 110 every so often. I've fixed a leaking power steering hose & see no other leaks. But it still needs more fluid, about every 2 months. Is this normal?
Old February 20th, 2014, 10:31 AM
Unless it is leaking, it can't lose any fluid.....
Old February 20th, 2014, 10:46 AM
I rarely have to add any. You likely need to add some stop leak.
Mark Kellgren
KM4BOR
Old February 20th, 2014, 10:53 AM
Probably leaking out of the selector shaft at the bottom of the box.
Old February 20th, 2014, 11:01 AM
ArmyRover's Avatar
ArmyRover
Bill Ski
83 110 "Frankenstein"
I add some about every 3 days. I have some pretty epic leaks on the steering box.
Unknown Author
716-898-8153
Old February 20th, 2014, 11:27 AM
the stop leak fluid seams to work quite well ... it causes rubber to soften and expand .... i used some in an emergency on my MTB disk brake ... worked fine for that ride but locked solid about a week later. Don't mix and match fluids people.
Old February 20th, 2014, 03:06 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Originally Posted by armyrover View Post
i add some about every 3 days. I have some pretty epic leaks on the steering box.
(lol)
Old February 20th, 2014, 09:20 PM
Talleyrand's Avatar
Talleyrand
1998 Defender 110 CSW 300Tdi
For me, a liter of stop leak every day. LOL. I buy it in bulk.
Old February 20th, 2014, 10:42 PM
If you have to top it off, then you have a leak.
Old February 20th, 2014, 10:43 PM
Howski's Avatar
Howski
Kevin
2002 Land Rover Discovery II
This thread makes me glad I've got a manual steering box
My other car's a Land Rover
Old February 20th, 2014, 10:49 PM
ArmyRover's Avatar
ArmyRover
Bill Ski
Glad to see someone in worse shape than I am
Unknown Author
716-898-8153
Old February 21st, 2014, 07:32 AM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Funny as I was just checking fluids yesterday and noticed my PS fluid seemed low. I opted to top it off with BG's PS fluid conditioner. I've never used it before but a mechanic I know said he has seen good results as systems get up in age.
Clay
Old February 21st, 2014, 08:25 AM
I added Lucas PS stop leak to both my 110 and my wife's D2, and it completely arrested all leaks. I maybe check both vehicles once a month max now. Maybe add just a little bit every quarter.
in my experience most PS leaks usually are associated with the hose to reservoir clamp.
Mark Kellgren
KM4BOR
Old February 21st, 2014, 10:14 AM
rd10014's Avatar
rd10014
Ronnie
1993 NAS D110
Originally Posted by Overlander View Post
I added Lucas PS stop leak to both my 110 and my wife's D2, and it completely arrested all leaks. I maybe check both vehicles once a month max now. Maybe add just a little bit every quarter. in my experience most PS leaks usually are associated with the hose to reservoir clamp.
Good to know.
top
Power steering howling when turning Davis Defender Technical Discussions 13 October 25th, 2011 01:27 AM
Power Steering Box fluid tomaco1 Defender Technical Discussions 4 October 18th, 2011 10:10 PM
steering box; top leakage.. 97Ariesblu Defender Technical Discussions 8 January 18th, 2009 02:42 AM
power steering pump noise cgalpin Defender Technical Discussions 8 October 27th, 2008 06:11 PM
Vendor for Power Steering Pump Pulley wheel ? norros Defender Technical Discussions 0 January 19th, 2005 04:12 PM
