How often to change fluids? - Defender Source
Old August 26th, 2012, 09:53 PM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
Keep hearing key to long life is changing fluids before recommended intervals. So might be stupid and I sort of know this for various cars/trucks but wanted to see what was recommended and how often you guys are changing your fluids. Couldn't seem to find anything in the Workshop Manual.
Specifically for a 97 auto but throw in 94-95 manuals too. I am running all synthetics.
Oil ??
Diff Fluid ??
Auto Transmission Fluid ??
Brake Fluid ??
Transfer Case Fluid ??
Power Steering Fluid ??
And lubing joints ??
Thanks... sorry if this is super elementary.
Old August 26th, 2012, 11:12 PM
Grover's Avatar
Grover
Oil ??
Diff Fluid ??
Brake Fluid ??
You will many opinions on this.
I change oil every 3 months or 3k miles which ever comes first.
Cheers...
Old August 27th, 2012, 12:50 AM
grnrvrs's Avatar
grnrvrs
Paul
88
For anything that takes 90 wt I follow a dynamic change regimine where every week or two I top up what ever is low. Over time the old drips out and is topped off with new.
Brake and PS, every two years
Lube joints, every few months
Engine, every 3k or so
Coolant, every two years
1970 SIIA 88, Sold
Old August 27th, 2012, 07:44 AM
Naplm00
Matthew
I lube joints every oil change
Old August 27th, 2012, 09:36 AM
Manimal's Avatar
Manimal
Carl Jonsson
1995 NAS D90 #219
What joints do you lube?
Old August 27th, 2012, 09:42 AM
Grover's Avatar
Grover
Prop shafts, UJ's and tire carrier.
Old August 27th, 2012, 09:45 AM
Don't forget the tie/track rods, they need to be greased too...
Old August 27th, 2012, 09:47 AM
Naplm00
Matthew
eveything on my truck that has a zerk
fluid change on a ZF4HP22 D90_Camel Defender Technical Discussions 3 June 2nd, 2005 04:41 AM
SPARK PLUG Change Interval: norros Defender Technical Discussions 2 February 21st, 2005 03:03 PM
how to change headlight chirider Defender Technical Discussions 9 November 25th, 2004 05:59 AM
Sick Of Messy Oil Change javelinadave Defender Technical Discussions 17 October 12th, 2004 09:28 PM
trans filter change question J4hand Defender Technical Discussions 0 December 17th, 2003 11:58 AM
