How much winch? - Defender Source
Old January 28th, 2004, 01:40 AM
howellm70
Michael Howell
How much winch?
I'm looking to get a winch for my 90 and there are great deals on the Warn M8000 going on right now (I've seen it as low as $400). My only concern is whether this is enough winch for the vehicle. Thoughts?
Cheers,
Old January 28th, 2004, 03:52 AM
wicks's Avatar
wicks
Wicks
97 Defender LE SW #44
Prolly fine unless you are lifting the vehicle. But a Superwinch is better. Sometimes people have used ones for sale. Try eBay.
Old January 28th, 2004, 08:58 AM
chrisvonc's Avatar
chrisvonc
Chris von C
No Defender at this time
Ours had a M8000 and it did fine the few times we used it. I replaced it with a 9000 though when I had to get a new one.
Chris von C
[/size]
Old January 28th, 2004, 09:07 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You'll be fine with the 8000. Just get a snatch block or two to help ease the load and let it perform better.
Old January 28th, 2004, 11:39 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
A winch to be safe needs to twice the fully loaded vehicle weight, including gear and bolt ons. That means 9000, even 9500. Now, you can get away with less with snatch blocks and or not being very stuck. Now, superwinch better than warn? Uhh, let me check, um, no.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 28th, 2004, 11:44 AM
uh oh
Old January 28th, 2004, 11:59 AM
snuffer's Avatar
snuffer
Randy Black
'95 D 90 SW
Mike, I have a Warn 9000, it gets a lot of use, if I replace it I will go up to at least 9500, and I would give the worm drive Superwinch a good look before I buy.
The democracy will cease to exist when you take away from those who are willing to work and give to those who would not. -Thomas Jefferson
Old January 28th, 2004, 12:51 PM
howellm70
Michael Howell
Thanks for the advice. I'll look into superwinches for comparison. For those of you who think they're superior to warn I've gotta ask why - is it just because of the Husky worm drives?
White '95 D90 ST
BRG '92 RRC LSE
Black '02 RR HSE
Old January 28th, 2004, 12:59 PM
i think thats why most people like them
Old January 28th, 2004, 01:15 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Part Number:
47550 12V DC, Roller Fairlead
Rated Line Pull:
9500 lbs. (4309 kgs.) single-line
Motor:
4.6 hp/3.43 kw, Series Wound
Control:
Remote switch, 12' (3.7m) lead
Gear Train:
3-Stage Planetary
Gear Ratio:
156:1
Lubrication:
Molylube #1 or Aeroshell #17
Clutch (freespooling):
Sliding Ring Gear
Brake:
Automatic Direct Drive Cone
Drum Diameter/Length:
2.5"/9.0" (6.4cm/23cm)
Weight:
86 lbs. (39 kgs.)
Wire Rope:
125' 5/16" diameter (38m, 8mm diameter)
Replacement wire rope:
PN 25987
Fairlead:
Roller
Remote Control:
Included
Recommended Battery:
650 CCA minimum for winching
Battery Leads:
2 gauge, 72" (1.83m)
Finish:
Argent Powder Coat
Nuts/Bolts:
PN 37829
Warranty:
Limited Lifetime
HS9500i 12V DC Performance Specifications:
Line Pull
lbs. (kgs.)
Line Speed
Ft./Min (m/min)
Motor
Current
Pull by layer
layer/lbs. (kgs.)
0
62.0 (18.90)
67 amps
1/9500 (4309)
2000 (907)
16.3 (4.97)
160 amps
2/8650 (3924)
4000 (1814)
11.8 (3.60) )
230 amps
3/7920 (3593)
6000 (2722)
9.31 (2.84)
305 amps
4/7400 (3357)
8000 (3629)
7.59 (2.31)
370 amps
5/6940 (3148)
9500 (4309)
6.67 (2.03)
425 amps
Above specs are based on the first layer of the drum.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old January 28th, 2004, 01:29 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Just get the biggest one you can afford -- when you're stuck on the trial at 2am in a loaded truck and you're by yourself and it's sleeting and you can't find the snatch block because it's back at camp, you don't want to have to say "damn, I wish I'd coughed up that extra $100." Skimp on the stereo, don't skimp on the things that may save your butt.
Superwinch's have a knack for burning out solenoids, warns seem to be slightly better, but not great either.
Tony
Old January 28th, 2004, 02:01 PM
Craigd's Avatar
Craigd
Craig Dickson
1995 D90 Red Soft top
THe latest issue of Four wheeler had a pretty good article about winching and how to calculate how much winch you need depending on ground goo and how deep your vehicle. It also demonstrated techinques for winching around trees and such.
Old January 28th, 2004, 03:12 PM
tbmcneill
Guest
Posts: n/a
How much winch will depend a lot on who you talk to. Industry standard says 1.5 times loaded vehicle weight.
IMHO, the Warn 8274-50 is the best winch ever made. Its rated at 8k lbs, is serviceable, has an external brake (read: can use plasma rope without worry of frying it & you can't wear the brake out), can easily hold 125' of 3/8th cable (or rope) & is among the fastest of the fast winches.
the Husky's are good, but are way too slow.
If weight is a big concern or you don't have much space, go with a planetary .... though, I try to avoid them. Worm drives (huskys) and spur gears (8274) are just more durable than planetarys will ever be.
T
Old January 28th, 2004, 06:25 PM
artm
Arthur Maravelis
97 SW
I was just given an ARB and always liked the Husky. Am I out of luck? I reall reading way back that it can only hold planetaries.
Old January 28th, 2004, 07:16 PM
Art Vigil's Avatar
Art Vigil
Arthur Vigil
I have to cast my vote for Warn also, soley based on my experience with my X-9 which I toasted after about 5 years of ahem...'moderate' use.
Arthur M Vigil
Colorado Native
Former owner of:
'95 RRC - 3.9V8 Rimmer Supercharged!
'72 Series III 88" NADA Turner 2.25 petrol (Lovely Rita)
'95 RRC Brooklands/TWR Edition 3.9V8
'97 D90SW NAS #2426 - 3.9V8 Rimmer Supercharged!
'95 D90ST NAS#2620 - Original owner
Old January 28th, 2004, 07:56 PM
TDI Guy's Avatar
TDI Guy
2015 LR4
I have a 8274-50 from the 70's on my series truck and its a tank. You cant kill it.
Legend in My Own Mind.
Old January 28th, 2004, 11:36 PM
wicks's Avatar
wicks
Wicks
If you want a fast one get the Husky 8. If you want to winch semi trucks out of the grand canyon, get a 10.
Superwinch has been the choice of Land Rover all the years before they were taken over by foreigners. If that's not enough, John Lee has studied the differences to excess...
https://www.expeditionexchange.com/superwinch/
Old January 29th, 2004, 12:41 AM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
The first LR Camel Trophy event in 1981 sported the RR with a 8274 Warn, not Superwinch. Even with this truth, the first winch for a Land Rover was probably the Capstan or Koenig.
Old January 29th, 2004, 01:24 AM
tbmcneill
Guest
Posts: n/a
You can fit an 8274 with 1.5" spacers (I still have set laying around ... you can have them for shipping + box).
T
Old January 29th, 2004, 03:54 AM
wicks's Avatar
wicks
Wicks
OK well if we are going to start talking about "proof" or high truths, may I present some evidence...
Most people don't realize that Superwinch (makers of the Husky winch) are the same outfit as Fairey, who made the overdrives for series trucks also.
Yes DJ on CT - they used WARNS on accident a couple of times. I'm talking about factory Land Rover offerings spanning many years, starting with (yes ) Koenig and capstan-style winches, of SUPERWINCH (FAIREY) manufacture, starting in the 1940s and 50s, then of course being the first electric winch offered by Land Rover as a factory option starting with the Series II, IIA and then III.
The legacy of Superwinch and Land Rover is indisputable.
Wicks
ps - sorry so heady, but one of those chaps who still thinks in gil sans.
winch
used winch now engine runs weird cpk Defender Technical Discussions 6 March 5th, 2006 04:03 AM
Safari Gard winch bumper and winch m016324 For Sale - Parts 3 September 20th, 2005 09:52 PM
D-90 Winch Bumper Capt Milks For Sale - Parts 0 August 27th, 2005 08:35 AM
WARN 8274-50 Winch, THE ULTIMATE!!! RedRhinoProducts For Sale - Parts 0 September 28th, 2004 08:18 AM
winch help???? ccrover Defender Technical Discussions 3 March 4th, 2004 07:51 PM
