How much $$ to replace Rear Main Seal - Defender Source
Old October 16th, 2016, 07:22 AM
1991 Defender 200 tdi
Hi all,
I'm looking to have the rear main seal replaced (200 tdi) and probably the clutch while it's apart- any idea how much I can expect to pay for labour? Thanks!
Old October 16th, 2016, 07:36 AM
rdavisinva's Avatar
Guess Who?
I wouldn't do it for under 6 hours of labor, but it's probably more like 8.
Multiply by the local shop rate and you have a rough figure.
Get in touch with rovertek out on LI, NY and he can give you a reasonable estimate and is not terribly far away.
He does excellent work.
replacing 3.5L V8 rear main oil seal cgalpin Defender Technical Discussions 9 June 18th, 2008 12:03 PM
How much $$ to replace rear cross member everglades Defender Technical Discussions 4 December 20th, 2007 06:46 AM
Rear Main Seal Heath Defender Technical Discussions 1 March 15th, 2007 10:13 PM
Oil Leak, is it the oil pan or rear main seal??? Grover Defender Technical Discussions 4 January 22nd, 2006 08:24 PM
Rear main seal replacement howellm70 Defender Technical Discussions 4 May 20th, 2004 06:33 AM
