How much $$ to replace rear cross member - Defender Source
Old December 19th, 2007, 06:52 PM
everglades
Nando Zorrilla
1995/Defender
I know the part is about $400... what about the labor? Whats fair?
Old December 19th, 2007, 08:44 PM
Flagg's Avatar
Flagg
Flagg
1995 Defender 90 NAS
I think the part is about $350 from Rovers North. I have heard people say that spent $500 to $700 for the replacement. Depends on how rusty your truck is and how many connectors break when removing the old one..........
Flagg
Old December 19th, 2007, 09:17 PM
With extensions, the part is $450 or so the labor should be half a day or so. If it were me, I would buy a new frame.
Old December 19th, 2007, 09:40 PM
Cirbo's Avatar
Cirbo
Jim C.
There were issues on the one that I did. First of all, the replacement was Euro-spec, so it needed some bracketry removed with a plasma torch. Secondly, the frame rail extensions travel up far enough that they interfere with the NAS fuel tank mounting brackets. I ended up having replacement brackets fabricated, which increased the cost. After all that, you need to carefully cut the old brackets off, and weld the new ones in place. Oh, and guaranteed, you will break most all of the bolts when trying to remove the rusty fuel tank skid, rear bumper, and just about everything else.
Umm.... Have fun!
Ooo... almost forgot. You need to consider the fact that the rear harness will interfere with the extension on the passengers side as well.
Old December 20th, 2007, 07:46 AM
junkyddog11's Avatar
junkyddog11
oil soaked filter
95 RRC 300tdi
Usually a full day job at minimum X shop rate at your local Rover welding emporium.
Matt Browne
ac
rear cross member replacement question Cirbo Defender Technical Discussions 16 May 25th, 2008 01:04 PM
rear cross member 1of40 Defender Technical Discussions 5 December 1st, 2005 11:48 AM
Rear 3rd Member w/ 4.75 gears and Detroit orlandog For Sale - Parts 0 October 26th, 2004 10:09 PM
New Safari Gard 3-link cross member Davis For Sale - Parts 2 July 4th, 2004 05:00 AM
