How much is too much? Rust - Defender Source
Old August 1st, 2016, 08:38 PM
Gibson
Al
Hoping you gents can help me out. I recently found a 1998 Defender 110, 300tdi Imported from Germany into Canada and has pretty much been sitting for the last 2 years. I know that sitting is not good. Issue is the photos from 2 years back look good with minimal oxidation/rust issues. After viewing the truck I've found a bunch of concerns. I was hoping the find a truck that only required a frame cleaning/rust sealer/topical oil/wax application. I'm not interested in a frame replacement.
The rear bumper crossmember now has a flakey rust spot on the right side that I'm sure is a hole. The cross member that you would bolt up a bumper. The under carriage also has developed rust. I'm not sure of the rate of this but is concerning.
Does this look like a elbow grease type of job or am I into a frame replacement situation should I purchase this vehicle?
Drove really nice but owner couldn't produce and paperwork on maintenance history and carproof didn't have anything as it's never been registered or plated as yet. Only ownership. The motor had some concerns but that's another topic. I'll post some pictures but might have to do so in multiple posted.
I'd appreciate any insight.
Cheers.
Old August 1st, 2016, 08:39 PM
Gibson
Al
Old August 1st, 2016, 08:43 PM
Gibson
Al
Another
Old August 1st, 2016, 08:45 PM
Gibson
Al
Undercarriage
Old August 1st, 2016, 08:47 PM
martn
martin
my13 defender 110 puma
Looks like surface rust to me. Check the outriggers first
Sent from my Nexus 5X using Tapatalk
Old August 1st, 2016, 08:50 PM
Gibson
Al
Wheel area
Old August 1st, 2016, 08:52 PM
Gibson
Al
Rear bumper cross member. Right side has the hole. Was thinking a sand blast, weld filler and grind situation.
Old August 1st, 2016, 08:56 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
not bad at all...
Rent my
Old August 1st, 2016, 08:57 PM
Gibson
Al
Rear corner of cab. Steel corner trim needs replacing. Same on both side of rear.
Old August 1st, 2016, 09:02 PM
Gibson
Al
Floor drivers side. Looks like surface and seems solid. Wasn't sure if this what the bulkhead area that is often mentioned.
Old August 1st, 2016, 09:05 PM
Gibson
Al
Door lower, some small soft spots.
Old August 1st, 2016, 09:06 PM
Gibson
Al
My apologies, what would the outriggers be?
Thanks for the reply.
Old August 1st, 2016, 09:16 PM
Gibson
Al
Another rear. Right side has some wrinkles along the lower panel above the check plate. I'd assume prior minor impact or a sign of something else?
martn
martin
Behind front wheels arch, out rigger s are the metal support components for the body on each side.
They are mud traps.
Just look into the front wheel arch facing the rear of the defender you will see them.
Also nearby there is a gap where you can check the firewall/bulkhead. You won't be able to check the cabin side but surely the engine side.
Overall I think she looks good
Old August 1st, 2016, 09:19 PM
Gibson
Al
Another lower door.
Old August 1st, 2016, 09:33 PM
Gibson
Al
Lower body panel. Pretty much the same in both sides of the truck.
Old August 1st, 2016, 09:35 PM
Gibson
Al
Front lower body behind wheels
Old August 1st, 2016, 09:42 PM
SGS714's Avatar
SGS714
Scott Striglos
2xRRC 2xD90 2xD110 Series II, IIA
I see nothing that scares me.
Thank you,
67 Series II
71 Series IIa 88" ACR 2.8 Power Plus
89 RRC 2 door 200tdi
93 D110 NAS #327
94 2x D90 NAS #'s 1076 ACR 4.8, 1161 SBC
94 D90 NAS now a D110 HS 2.8 aka Project Wolf
95 2x RRC
1-SWB,Doing the LS Gen IV 98% Done
1-LWB 300tdi
Old August 1st, 2016, 09:47 PM
Gibson
Al
They are mud traps.
I had to fly out to see it.. I did also look from the engine bay side at the bulkhead from above. It looked clean. Would the area of concern be visible from that angle?
------ Follow up post added August 1st, 2016 08:56 PM ------
On another note.. Is it common to have some drive line slap?. When releasing the clutch there seemed to be a dumping shutter in the driveline when feathering in the shift at the initial engagement. Wasn't sure if it was just the Defenders unique suspension system flex.
Old August 1st, 2016, 10:02 PM
Gibson
Al
Shifter fork is said to have been replaced recently
How much smoke is too much?? RiftRover Defender Technical Discussions 13 May 2nd, 2016 03:02 PM
How much is too much??? Azarur Truck Build-up's & Restores 71 April 5th, 2015 12:55 AM
Is this too much rust? d110 svxaddict Defender Technical Discussions 27 April 8th, 2013 01:56 PM
Sagging Suspension: How Much is Too Much? aclarke Defender Technical Discussions 9 June 19th, 2007 03:41 PM
Rust, damn rust, and rust jaherring Defender Technical Discussions 14 September 2nd, 2004 06:27 PM
