How much $ do you have into your rebuild? - Page 2 - Defender Source
Old September 21st, 2011, 03:59 PM
ron's Avatar
ron
Ron
1994 NAS Defender 90
Smile
I put $10,000 in a truck that just need 2 fenders.
talk about might as well.......
Old September 21st, 2011, 09:35 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
restore
Originally Posted by GYM View Post
A lot depends on your definition of the always vague and often mis-used word "restore". If you were restoring to pristine original, off-the-factory assembly line condition, then - and, no offense intended - the amount you've spent so far is chump-change.
If you are taking the more common route of restifying/refurbishing/modifying and use a lot of non-original and aftermarket parts to create a nice driver or offroader, it will likely be less expensive, (and result in a more reliable/capable/fun vehicle.)
Make no mistake about it, either way, your checkbook has a lot of heavy lifting left in front of it...
The most simple part of ANY restoration is already behind you, namely the acquisition of the truck itself.
I love this thread! Lots of valuable insights.
I am taking this more common route mentioned above. Even though I stripped everything down to the frame and started over I am restoring it to what I want (and can afford) with what I have access to. I'm looking forward to having a rust free daily driver with a fuel injected 4.2 ltr, automatic, and air conditioning but I know it won't be pristine or original by any means. I'm going for tough, cool looking and semi-practical. I really want to see this thing on the road already but I'm absolutely loving the rebuild process. It gives me a great feeling of accomplishment and I'm definitely learning a few things along the way. It realy helps to have an older brother who was a Land Rover master tech at the dealer for a dozen years living near by. I'm taking alot of pictures along the way and am looking forward to making a build thread in the project section when I'm done, which I hope to be in about 6 months or so.
Old September 22nd, 2011, 09:02 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
You should start the build thread now, not when you're done.
Old September 22nd, 2011, 03:09 PM
One Ten's Avatar
One Ten
Sam
1994 NAS SW
Will do
rebuild
8274 Brake rebuild Red90 Defender Technical Discussions 4 October 4th, 2005 10:52 AM
Ideas for CVC's "banana flambe" rebuild evilfij Misc. Chit-Chat 24 September 23rd, 2005 01:10 PM
Rebuild Costs kjh888 Defender Technical Discussions 4 September 14th, 2005 12:40 PM
LT230 needing rebuild Abrooks For Sale - Parts 15 October 4th, 2004 10:14 AM
