How many tie rod ends do I need 2 or 4? Proline or Genuine? - Defender Source
Old September 24th, 2013, 11:46 AM
bradfordish's Avatar
bradfordish
Bradford
95 D90 SW #141
Shop says mine need to be replaced and prefer to order them myself and save some $$$. Also, anyone one used the Proline version?
Thanks.
Old September 24th, 2013, 11:50 AM
Get genuine...not a big fan of the aftermarket for these. You need 2 on the tie rod (in back of the axle), but keep in mind one is reverse thread. You'll also need 1 for the drag link (in front of the axle) if you're doing that one as well....can't recall which thread that is, but the Parts Manual should indicate. You'll probably be better off ordering them up yourself and having them shipped directly.
Old September 24th, 2013, 11:56 AM
I'm with Jason on genuine parts for some things, but I make an exception for stone-age technology wear items like ball joints that are all probably made by the same manufacturer somewhere in the Far East or Eastern European countries.
I'd personally recommend getting on rovahfarm.com and ordering the cheapest R/H and L/H ball joints.
Old September 24th, 2013, 12:00 PM
The aftermarket are actually different...the genuine are a sealed unit, whereas the proline/etc are tapped with a zerk and the boot is different (cheaper in my opinion). I "borrowed" an end from Huff, and he was not pleased when I handed him back a Proline . So I ordered up a genuine from RN and took the Prolines and put them in a box of trail spares.
Old September 24th, 2013, 12:13 PM
bradfordish
Bradford
95 D90 SW #141
Thanks for the info and advice guys!
genuine, proline
Heavy Duty Track Rod Kit with Tie rod ends $250.00 SafariHP The Vendors Loft 0 August 30th, 2012 04:20 PM
Tie rod end - metric or inch? byrdseye Defender Technical Discussions 3 October 1st, 2009 06:57 PM
Stuck Tie Rod NashvilleRedD90 Defender Technical Discussions 9 October 9th, 2007 01:54 PM
Tie Rod problems ... Help! Palmer Defender Technical Discussions 3 January 14th, 2004 08:41 AM
SG Rock Gard (tie rod guard) dmarchand For Sale - Parts 8 October 28th, 2003 01:39 PM
