How Many of You have Broken an Axle? - Defender Source
Old April 20th, 2008, 10:53 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Yesterday I decided to test my skills with some buddies down in Farmington NM. They were driving very modified jeeps and other rigs. If any of you have seen/been to Farmington, you know what I was in for. Well I figured out a few things. First and most importantly, I need more skills. Secondly, I need a stronger drivetrain. I was attempting to climb a rather technical section with large rocks and ledges when i heard the dreaded noise, SNAP. Then no power to the rear. I have Trutrac in the front and rear. I'm pretty sure it was my driverside rear axle. I drove home with the center difflock on about 50 miles and everything felt fine. I assume it was 3 wheel drive. Is it ok to drive this way while waiting for a replacement from rovertracks?
Any recommendations while I'm at it.
How many of you have also broken an axle? I'm interested in your story and what you did to fix the problem.
Old April 20th, 2008, 11:10 AM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Well you already did it so it doesn't matter now. I would have pulled the axle to inspect and remove the broken bits and be sure no pieces were left to float into the diff. You were front wheel drive only most likely as the TT would have zero resistance from the broken side, assuming a clean break, and not bias the power to the unbroken side.
Old April 20th, 2008, 12:32 PM
MontanaD90's Avatar
MontanaD90
Richard
95/ Defender 90 NAS
yeah Defenders have full floating axles which make it not that hard to pull them and make sure it is a clean break and there isn't small pieces getting in where you really don't want them.
I bought it to use it
If its not fun, why do it
Old April 20th, 2008, 12:44 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Welcome to rocks. They can be tough.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old April 20th, 2008, 03:04 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
If you have trouble removing the axel, you can press it through from the other side (just take out the other axel (it will save mucho time comipared to fiddling with magnets!). Something small in diameter so it can fit through the opening on the Trutrac. For on trail repair, I used my CB antennae.
Old April 20th, 2008, 03:52 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Very nice.
I pulled the passenger axle and it was a clean break right at the hub flange. Rovertracks will be getting a call in the morning. My front axle/cv's will be stock for now. Are they next to go?
Old April 20th, 2008, 07:02 PM
KevinNY's Avatar
KevinNY
Kevin Buckley
1973 coiler
Originally Posted by mdmccallum
Very nice.
Get his rear axles now and wait til his front's are back in stock, then buy them. Nothing like some piece of mind.
Old April 21st, 2008, 06:19 PM
AggieD90's Avatar
AggieD90
Kevin Collins
'95 AA Yellow & '97 Willow Green
I have once. In the rear. It was the second time I was out after the ARB went in. Replaced with GBR and never had another problem.
Old April 21st, 2008, 07:20 PM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
In this situation I personally would have also pulled the rear driveshaft. It's not a big job and then you have no torque going to the rear axle at all. I imagine that running only one driveshaft would increase the stress on the other one.
If other wiser individuals feel this is an unnecessary step I'd like to hear about that.
- Andrew.
1986 110 CSW 200tdi (
Old April 23rd, 2008, 05:28 AM
paul c
paul critcher
85 110
- Andrew.
driveshaft as in prop shaft? cant be any stress as there is no load on one side, like turning a shaft on bearings with nothing on the other end. best to remove the broken half shaft though.
Old April 23rd, 2008, 06:25 AM
aclarke's Avatar
aclarke
Andrew Clarke
1986 110 CSW 200tdi
mdmccallum has a TrueTrac in his rear diff. So if the propshaft is still in place, it will be driving the one wheel that still has a half shaft going to it. The other side of the TrueTrac will be running with no resistance due to there being no half shaft, which places an uneven load on the TrueTrac. I guess from that point of view though having the propshaft/driveshaft off will still result in uneven loading on the TrueTrac as one wheel will be driving it but the other won't. You can't win
- Andrew.
Old April 23rd, 2008, 06:13 PM
paul c
paul critcher
85 110
as mentioned above the truetracs require some load on an axle to operate, if a wheel is spining freely it wont lock up, applying the brakes slighly will cause it to lock. as the axle is broken it cant be loaded, unless the broken ends are jagged and catch on each other, which is why it would be advisable to remove the broken pieces.
axle
Seal at axle tube/swivel ball snuffer Defender Technical Discussions 8 February 7th, 2011 05:06 PM
1997 Defender 90 Rear Axle Casing Steve Friedman Wanted 3 March 8th, 2009 07:33 PM
Broken Axle Shaft, What to do with it mdmccallum Defender Technical Discussions 7 May 8th, 2008 12:52 PM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
new rear axle rolaro Defender Technical Discussions 8 January 26th, 2005 11:34 AM
