How many bleeder valves? - Defender Source
Old October 8th, 2008, 09:19 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I know I can look but my d-90 is at home and this on my mind now, how many bleeder valves are on each caliper? One or two?
Old October 8th, 2008, 03:49 PM
wcampbel@nas.edu's Avatar
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Pretty sure it is just one per caliper.
B
Old October 8th, 2008, 06:30 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
Yep !
Just one.
Pat
Kirk Lazarus, Tropic Thunder
Old October 9th, 2008, 10:22 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
Darn, I can't get my brakes the way I want them. Once the same thing happened on my race car and I simply never noticed there was a bleeder valve on the inside of the caliper as well. I was hoping it was the same situation... Do they make after market calipers for land rovers? I checked the normal places, brembo, stoptech etc. and nobody makes stuff for our cars. Has anyone ever fitted range rover sport brakes onto a defender or something like that?
Old October 9th, 2008, 07:58 PM
Oxcart13's Avatar
Oxcart13
Mark M
D110
What condition are you trying to overcome?
Old October 10th, 2008, 12:29 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Like Oxcart was asking, what seems to be the problem?
The brakes on these things are absurdly over-powerful, and is the one area I've never seen a complaint about performance that didn't involve a problem.
My oil line fix
My 100k stopped odometer fix
Old October 10th, 2008, 09:35 AM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
I have two problems.
First the pedal travel is far too long. It's going to the floor almost. Second, low RPMS (especially offroad) the pedal needs to be pumped up to pressure. Just recentyl, My clutch has started to need pumping after it's been sitting.
First issue is indicative of air in the lines. Second Issue seems like a vaccum leak. I checked the line from the booster and it seems fine. The problem is made worse off-road so I thought maybe a hub nut was loose and was wiggling the pads apart, just redid the bearings and the problem is still there. I've been chasing this for over a year now. It no longer brakes in a straight line, and it getting a little scary to drive. I'll get a bleeder and replace the fluid with superblue and do a good long bleed and that should harden up the pedal but the pumping issue is a problem.
Old October 10th, 2008, 11:31 AM
Hans's Avatar
Hans
Hans Haase
vacuum leak would make the pedal harder to press, not softer. Which side does it pull to when braking? I'd check the OTHER side from that. Are you losing fluid at all?
Maybe have a shop do a full flush and pressure-bleed the system might help?
Also, just as a wild idea, you do have the vented rotors, and not the solid ones? Correct?
-Hans
My oil line fix
Old October 10th, 2008, 11:38 AM
Bad master cylinder.
Old October 10th, 2008, 12:46 PM
taoseno's Avatar
taoseno
Todd Kendrick
1995 D90 #2206 Original Owner
I have had the same problem for over a year. Brakes pedals wants to go to the bottom off road; pump a time or two and it is fine. On road seems OK pedal stays at the top. I have adjusted the bearings numerous times w/ no improvement. I noticed this started after replacing the master cylinder w/ a genuine one so maybe Ron you are on to something. Have you had this issue before? How to check the master cylinder? Sorry we missed each other in Moab; saw your truck but you were not around...........
Todd
'95 D90 #2206
'66 109" P/U
Old October 10th, 2008, 01:00 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
My fault, I meant a leak in the line somewhere, not a vaccum leak. I am not loosing break fluid, but there is a seperate resevoir for the clutch right? D-90s don't share brake fluid btw. the brakes and the clutch do they?
Is it difficult to change a master cylinder? Never opened one up before
Old October 10th, 2008, 01:24 PM
Seperate cluch res intergal to the clutch MC does not share with brakes. Change of a D90 MC is super easy with two bolt that is all that is holding it on, make sure to bench bleed it before install. I recommend castrol GTLMA as the only fluid to use.
If it is only happening offroad, tighten your wheel bearings.
Old October 10th, 2008, 01:58 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Ok crazy question but why tighten the wheel bearings?
Old October 10th, 2008, 03:29 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
If they are loose then the josting off-road would cause the hub to rock back and forth. Since the rotor is attached to the hub it too would rock back and forth pushing the pads apart which is why you would have to pump the pedal to get brakes. I have already checked this on my truck and it's not the issue. I might try the MC but I have no idea what "bench bleeding" is
Old October 10th, 2008, 03:57 PM
Hans's Avatar
Hans
Hans Haase
Bench bleeding is pre-bleeding the new master cylinder before installing it into the truck. Necessary step on any car actually.
-Hans
My oil line fix
Old October 10th, 2008, 04:03 PM
wcampbel@nas.edu
Bill Campbell
1994 D-90 ST
Oh ok. Could warped rotors or warped wheels cause the same problem?
B
Old October 10th, 2008, 04:16 PM
sflash868's Avatar
sflash868
Stephan Laputka
1995 D-90 SW
You could never warp a rotor to the point where it was pushing your pads apart. Warped rotors will really only screw you when you press the pads against the surface sending shudders throughout the car.
bleed
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Motive Power Bleeder Antonios For Sale - Parts 2 November 18th, 2007 05:24 PM
power bleeder psi D90user Defender Technical Discussions 1 October 5th, 2006 11:29 PM
power bleeder thewap Defender Technical Discussions 1 August 4th, 2006 07:03 PM
