How long should brake lines be ? - Defender Source
Old November 7th, 2007, 07:06 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
I'm doing the standard 3" lift on the 110. And I see when it comes to braided brake lines I see +2", +4" and +6" and I ask my self if it would be worth while to get more than is requiered or stay with the +4".
Thanks for your input as usual.
Pat
Kirk Lazarus, Tropic Thunder
Old November 7th, 2007, 07:26 PM
LRNAD90's Avatar
LRNAD90
Scott T
1995 Defender 90 ST
Hey Pat,
It is really going to depend more on the extended length of your shocks than the amount of lift. If you run a stock length shock, in the stock position, the factory lines are sufficient, since the axle cannot droop anymore than it could when the suspension was stock. If you go with a shock that is 2" longer extended length, and the shock is in the stock position, then +2" is sufficient, and so on.
~Scott T.
'95 D-90 ST - AA Yellow
brake
Brake lines? ajh Defender Technical Discussions 18 February 22nd, 2009 11:51 AM
extended brake lines jimmy salmon Defender Technical Discussions 12 February 27th, 2006 11:07 AM
Clogged brake lines? Heath Defender Technical Discussions 11 February 24th, 2006 08:39 AM
Hard brake lines! TwisteD90 Defender Technical Discussions 10 October 10th, 2005 12:12 PM
Stainless steel extended brake lines Chris Cox For Sale - Parts 1 February 8th, 2005 01:34 PM
