How does the inertia switch/circuit work? - Defender Source
Old April 2nd, 2016, 03:47 AM
lithium1330's Avatar
lithium1330
'97 SW NAS 4.6
Hi, I new to Defenders, and did some reading to learn about the inertia switch and its purpose.
I was wondering if someone can explain how switch works?
How is the circuit triggered? I've read mentions of roll-over to even hard jolts/bump.
Also, I assume it's a closed circuit until the switch is tripped. At which point, the circuit is open (broken), and fuel pump, etc. stop working. Is this correct?
Thanks!
Old April 2nd, 2016, 07:17 AM
You'll actually find them on all cars. Purpose is to shut down circuits like fuel pump in event if an accident. Also to activate airbags etc. https://en.m.wikipedia.org/wiki/Inertial_switch
Have beaten up trucks very badly and never triggered one. Don't worry about it.
Old September 10th, 2016, 07:11 AM
sad_story's Avatar
sad_story
andre
95' D90
Does unplugging it disable the switch? In other words, if I am trouble shooting would unplugging it eliminate it as a possibility for not starting?
Old September 10th, 2016, 07:38 AM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
I've triggered mine once...at Uwharrie of all places.
'91 RRC 14SUX truck pulled it into campsite after a trail ride fine and then 5 minutes later COULD NOT get it started for anything.
After checking this/that and everything else someone suggested the inertia switch and sure enough... it had popped up.
Rent my
Old September 10th, 2016, 08:06 AM
Roverlab
Trevor Griffiths
85 110, 92 110, 92 RR, 06 LR3
Andre, unplug it and the Rover wont start.
Email is
Same place, new dogs.
Old September 11th, 2016, 06:04 AM
sad_story's Avatar
sad_story
andre
95' D90
switch
Defender hazard switch and Inertia Seat Belts triple9music For Sale - Parts 1 December 18th, 2012 12:33 PM
Inertia - Fuel Cutoff Switch 61rover Defender Technical Discussions 4 June 6th, 2012 07:06 PM
Fuel pump or inertia switch SIIA109 Defender Technical Discussions 2 June 21st, 2010 11:28 AM
94 with AC- how to get to the inertia switch ? Doug Crowther Defender Technical Discussions 3 September 8th, 2006 03:11 PM
What is the Inertia Switch for? Mark M Defender Technical Discussions 9 December 21st, 2004 11:06 AM
