How does one disassemble an older style dash? - Defender Source
Old January 16th, 2010, 11:52 AM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
1983 110, 1985 110, 1993 110...
I am going to be adding a couple more indicators and was wondering hoiw to get the dash apart to route wiring.
IPSC_GUY
SIERRA II ALPHA
Old January 16th, 2010, 12:33 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
Try not to take the dash apart if you can. Depending on where and what the indicators are, you can use a "snake" and pull wire through to where you want.
Old January 16th, 2010, 04:17 PM
IPSC_GUY's Avatar
IPSC_GUY
Peter/Lesbo
Really? Why is it inadvisable to go digging into the dash? the indicators will go in the center section and one will be a boost gauge so I need the hose intact.
IPSC_GUY
SIERRA II ALPHA
Old January 17th, 2010, 03:46 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
IPSC_GUY
SIERRA II ALPHA
Nothing bad will happen, it's just a lot of screws and takes a long while. You may find a few fasteners missing and cure some rattles along the way
Mike Hammond
Old January 17th, 2010, 07:16 PM
Hoosier's Avatar
Hoosier
Chris Hinkle
More than I need
It's just a pain to take it apart and put it back together again - especially if you're just dragging 4 wires to a two guage cluster.
Old January 17th, 2010, 08:15 PM
I've put in a ton of gauges and never taken the dash apart. There are two conduits along the back. You can fish wires or tubes through them easily.
Old January 17th, 2010, 10:13 PM
done this too. much mo' better than any kind of dash disassembly!
dash
Rockware(Warn 8274) style Winch Bumper, Tire Chains Set and Aluminum Dash Cowl MTC280 e90miller For Sale - Parts 11 January 29th, 2010 06:24 PM
Dash Rotted Out, Had to Fix It JimC Misc. Chit-Chat 7 February 6th, 2009 03:20 PM
Stereo Install In Dash caschumann Defender Technical Discussions 18 November 4th, 2004 12:41 AM
Newer LT-230 in older rig... h2eater Defender Technical Discussions 9 July 30th, 2004 08:07 PM
1997 Dash panel - what's there? ronward Defender Technical Discussions 6 April 26th, 2004 05:47 PM
