how do you unlock seat belt, can't get it to free up - Defender Source
Old August 15th, 2004, 10:26 PM
draaronr's Avatar
draaronr
Here
LR3
I took out my interior to get my vehicle rhinolined, and I cannot get the seatbelt to lengthen so that I can reattach it. What is the trick it stays all coiled up on the spring loaded end. Pics and/or description would be great.
Old August 15th, 2004, 10:31 PM
pull slow
Old August 15th, 2004, 10:34 PM
draaronr's Avatar
draaronr
Here
LR3
tried that, should I let it take it all then start pulling slowly, I was afraid to let it get all the belt, for fear it might bind due to the large spool.
Old August 15th, 2004, 10:41 PM
TwisteD90's Avatar
TwisteD90
Yousef Hamzeh
06 RR SC, 06 LR3, 94 D90
Thanks for posting this Aaron! I have the same problem. I just bought a pair of seat belts and one is locked. I tried everything with no luck Come on people give us some idea's
Old August 15th, 2004, 10:42 PM
mattdh's Avatar
mattdh
Matt Hurst
hold the reel in the postion it would be bolted in (level-staight up and down)and try pulling up on the webbing-you may need to give the reel a good tap
Old August 16th, 2004, 08:28 AM
ronward's Avatar
ronward
Redsrover
None - sadly
Don't let the spool take up too much of the belt. I had the same problem on my 110 and on the rear belts in my 90. Remove the reel from it's mounting point and try shaking it around a bit. There's a small (15mm maybe) steel ball in the reel mechanism that shifts fore and aft with the braking motion of the vehicle. This is what controls the spool inside the reel. It can get jammed easily if not held in the exact correct position. The plastic surround of the reel can be removed and refitted (might have to break off a tiny plastic tab and reglue--what I did on my 110) to free it up.
The only other fault that could cause the spool to seize within the reel is if the belt itself is frayed on the edge. Both rear belts on my 90 had frayed edged from where they baffle in the wind with the top down. I trimmed the "fuzz" from the frayed edges with a flame and all is well now.
Hope this helps.
Old August 19th, 2004, 02:57 PM
draaronr's Avatar
draaronr
Here
LR3
I know how to prevent it from happening now. I pulled out an extra 6to8 inches and put a ziptie above the spool, so it couldn't pull it in. Just a little fyi
Old October 11th, 2006, 12:11 PM
themaxx's Avatar
themaxx
Ade
94 ST
Thumbs up
I received a call over the weekend from the guys at Line-x, they were having troubles getting my seatbelt bolted back on. Found this old thread and walked them through the process. I guess there is a pendulum in there that has to be positioned juuuuuuuuussst right.
Thanks D-90 source!
PS...They did a FANTASTIC job!
Old October 11th, 2006, 01:19 PM
DJ Menasco's Avatar
DJ Menasco
DJ Menasco
#500/500
Thanks D-90 source!
Post some pics!!! I'd like to see it.
DJ
Old October 11th, 2006, 02:13 PM
themaxx's Avatar
themaxx
Ade
94 ST
DJ
I will take a few pics and post tonight!
Old October 11th, 2006, 03:30 PM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Sharp smack to the side of it will release it as well.
Email:
Old October 14th, 2006, 01:20 AM
Roverowner's Avatar
Roverowner
Brian Love
95/Disco
bad things are afoot if "sharp smack" is the beginning of anything that I am fixing is one of the steps.....
Inspirational Thought of the Day
Some people are like Slinkies ...
Not really good for anything, but they still bring a smile to your face when
you push them down a flight of stairs.
1995 Discovery
Rear Seat Belt Brackets zed111 Defender Technical Discussions 11 August 6th, 2007 02:45 PM
Need Rear Seat Belt Receiver for D-90 ST YellowD90 Wanted 0 November 5th, 2005 11:54 PM
Seat belt! TwisteD90 Wanted 3 July 8th, 2005 08:03 PM
Lap seat belt for the rear - flip up seat paulb Defender Technical Discussions 2 January 27th, 2005 03:43 PM
Lap Seat belt for a Trakker fold up paulb Wanted 0 January 24th, 2005 11:56 AM
