How do you start stand alone engine? - Defender Source
Old February 13th, 2016, 01:35 AM
DailyDrivenDefende
Michael
1989 110, 1985 90 200TDI
Hi guys,
How do I start stand alone engine? 200tdi if that information is needed.
Connect fuel line to any container of diesel and just crank a away?
Thank you.
Old February 13th, 2016, 05:35 AM
BlackField's Avatar
BlackField
Oscar
D110
12V to the fuel stop cutoff.
The following is my educated guess: Priming the lift pump might be a good idea. If I had to do it I'd likely use a 12v pump or a hand pump with a line filter to the inlet side of whatever is present from the fuel system. If you get it running turn off your 12v pump to see if the lift pump is doing its thing.
Old February 13th, 2016, 08:00 AM
slorocco
Dan Prasada-Rao
1963, 109 Station Wagon
Probably already thought of this but don't forget water if you are going to run it for more than a minute. May also need to account for oil if it's set up to push out to an oil cooler.
engine, start
This is what happens when you throw out you TV stand evilfij Misc. Chit-Chat 9 March 9th, 2015 11:15 AM
Paint wheels black or leave em alone? speedpin Misc. Chit-Chat 36 January 1st, 2015 05:24 PM
Engine Stand for 3.9L (Thread size?) Grover Defender Technical Discussions 1 April 13th, 2007 10:40 PM
Need 3.54 ring and pinion [alone] RedRhinoProducts Wanted 3 November 28th, 2005 09:19 AM
alone in the universe/ florida panhandle Rover- Girl Misc. Chit-Chat 50 April 1st, 2005 02:19 PM
