How do you replace a speedometer cable? - Defender Source
Old April 10th, 2010, 12:37 AM
aosias's Avatar
aosias
Alexandra
1995 D90
Same story as everyone else...had the dash apart, put it back together, speedo not working, took it apart again and it looks like I broke the plastic piece that holds the cable to the speedometer- the housing is broken but the inner cable is still connected.
I know I can duct tape the plastic bits together and get enough tension on it to work but I was thinking I'd just replace the cable myself (famous last words).
So, how do I do that and can I get it cheaper than RN for $100?
Alex
Old April 10th, 2010, 12:57 AM
bjf's Avatar
bjf
barry f
94 ST #395
Do a search on the part number. YOu can get it cheaper form places like britcar. It is easy. Cable goes through the bulkhead and attaches to the transfer case. Just follow the old and put the new in the same way
Old April 10th, 2010, 08:23 AM
I was playing with this last weekend ... I never managed to find a cheap version and repaired mine .... But the cable goes through a bulk head grommet at the top and goes down vertically through the engine bay, it's held in place by a metal clip which you can remove it from quite easily. At the transfer case end it screws on and is easily removed by hand.
Old May 6th, 2010, 01:46 PM
aosias's Avatar
aosias
Alexandra
1995 D90
Anyone have a photo of where the cable attaches to the transfer case. In my brilliance I can't seem to see that from under the truck.
Old May 6th, 2010, 02:05 PM
On the left side, bewteen the parking brake and the back of the transfer case.
Old May 6th, 2010, 06:27 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
I took mine off by pulling it through the bulkhead and off the transducer on the frame rail. I replaced mine with a VDO this week and had the adapter cable made for $20. Since you only need the end replaced, if you take all the parts to a local speedo shop, I can't imagine it being much more. If you are in Denver, call Deluxe speedo and ask how much it will be.
Bill
Old May 6th, 2010, 06:33 PM
bjf's Avatar
bjf
barry f
94 ST #395
I forgot the transducer. You should be able to find it easily.
ac, speedo
Speedometer cable mod for VDO - shop? mgrgpg Defender Technical Discussions 20 December 27th, 2013 11:57 AM
Detach Speedometer Cable Matt Klapmust Defender Technical Discussions 2 October 2nd, 2013 01:43 PM
Upper speedometer cable 94 NAS D90 Kilgore503 Wanted 10 February 18th, 2010 12:59 AM
Upper Speedometer Cable rmuller Wanted 0 May 1st, 2008 11:58 AM
Speedometer cable... standard threads down below? Hans Defender Technical Discussions 0 January 13th, 2007 09:33 PM
