How do you remove the CV from the axle? - Defender Source
Old December 12th, 2004, 05:38 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I have the front end completely dissasembled and the CV is holding onto the inner axle and won't let go. My book says tap with a mallet, no way, won't budge. I really need some help here, thanks!
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old December 12th, 2004, 05:56 PM
Get a bigger hammer.
Wiggle it a bit too, sometimes the splines wear and they lock together.
It will come apart.
Something like a vice, 2x4 and a 10lb sledge
Ron
Old December 12th, 2004, 08:57 PM
pendy's Avatar
pendy
jim pendleton
89'd90
Find a pipe that is just bigger then the axle. Then drop the axle into the pipe to remove the CV from it. Something like that.
JP
legend in my own mind
Old December 12th, 2004, 09:10 PM
I had one where the spring clip got jammed and was a biatch to get off. Broke the cage getting it apart with a hammer. The pipe method seems to be the safest.
Old December 12th, 2004, 10:52 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
CV's suck.
BUCK Wild Racing
Driver: Me
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
axle
Clutch Master/Slave Cylinder Hydraulic Leak Merged Threadfest Buckon37s Defender Technical Discussions 223 September 1st, 2014 01:49 AM
Seal at axle tube/swivel ball snuffer Defender Technical Discussions 8 February 7th, 2011 05:06 PM
Symptoms of a bad axle CV joint? Hans Defender Technical Discussions 16 April 6th, 2007 01:20 PM
remove front diff? scoloco Defender Technical Discussions 31 April 7th, 2005 03:23 AM
24 Spline Axle Shaft (Long Side) + CV Joint + Rear Housing mudrover For Sale - Parts 0 March 2nd, 2005 09:48 AM
