I replaced the oil cooler lines and I think that is what caused the pump to loose its prime. I know you can take it off and pack it with Vaseline, but I also heard that you could undo one bolt and pack that full of Vaseline. What would you recommend me do? I am attaching two pictures of the bolts that I think are the ones. Could someone please let me know which bolt it is or if I should just take the pump off and pack it with Vaseline?
Picture One
Picture Two
How do you take the pump off and pack it with Vaseline?
I did have the motor running for about 10-15 seconds with out oil. Do you think I did any damage to the motor?
Russ
Picture One
Picture Two
Russ
