How Do You Keep A Defender 90 Running When - Defender Source
Old July 23rd, 2015, 08:36 PM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
They don't make parts for it anymore? I had to take my 1994 Defender 90 into the shop because of erratic idle and engine stalling out. The problem turn out to be a hose is falling apart. The shop said can't get the hose from Land Rover anymore and if they could it would be around $400.00. They jury-rigged a fix using the old hose but what will I do when there is no more hose to fix? And $400.00? What is that hose made of? Mammoth intestine? The part is PART NUMBER: ESR1316 DESCRIPTION: Pipe - cleaner to plenum. Someone must have run into this problem before!
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old July 23rd, 2015, 08:45 PM
rovertek's Avatar
rovertek
chris
D130, 2001+99 p38
rovers north PHH100290 has been out of them but call and see if you can back order it or availability
No Mall crawler here
Old July 23rd, 2015, 08:46 PM
If you mean the intake hose, you do a search on this forum and presto!
We've already solved the problem!
http://www.defendersource.com/forum/...tch-60414.html
Old July 23rd, 2015, 08:50 PM
genie90's Avatar
genie90
Jay Geaney
1994 D-90 ST #282
Originally Posted by Rocky View Post
If you mean the intake hose, you do a search on this forum and presto! We've already solved the problem! http://www.defendersource.com/forum/...tch-60414.html
And from experience it works wonderfully!
Old July 23rd, 2015, 09:08 PM
I think it was mammoth foreskin, but don't worry, most of the stuff is more readily available, and if not, solutions have been made. When it gets real bad, we'll all be doing LS swaps or the like.
Originally Posted by pendy
I'm here for the D's
Old July 23rd, 2015, 09:32 PM
presto is right.. or you could use a 4" hose..
When the motor wears out you upgrade to a diesel (pick you favorite Defender one and it will fit) or an LS motor.
95' D90 - daily driver..
Old July 23rd, 2015, 10:47 PM
Yeah seriously. That's what this forum is for in the first place - to keep these things running! By the way weren't you experiencing the symptoms of this hose failure last July?!
Old July 24th, 2015, 06:55 AM
Capt Milks's Avatar
Capt Milks
Defender V-8, Defender 2.25
It is not pretty but you can get a hose from the performance section of the auto parts store. You will also need to get a couple of adapters as the hose ends need to be a little different, ie air cleaner vs plenum. It will get you by until one of the vendors starts making some more.
Old July 24th, 2015, 09:26 AM
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
I'd be surprised if a wrapped layer or two of Gorilla tape would not work in a pinch (or forever). Or the specialized high temp and pressure tapes (although these are $$ and not necessary for this application).
Old July 24th, 2015, 09:38 AM
Originally Posted by rlynch356 View Post
Lol - truth.
Old July 24th, 2015, 09:43 AM
Sigworthy!
Old July 24th, 2015, 11:25 AM
lol - done !
the tape idea is a good one... if your really in a bind i can send you my old one until you can get a silicone one from Ash. Then just send it back to me when your new one comes in. let me know
Ash's are very nice.
also - frankly i would look the ignition amplifier - mine started to go and resulted in some of the same symptoms (and a hard start)
90, defender, defender 90
What old part do you keep after replacing? MonLand Defender Technical Discussions 1 January 15th, 2013 10:42 PM
Oil Cooler on D90- To keep or not to keep - that is the question! flananuts Defender Technical Discussions 10 April 25th, 2012 11:24 PM
easy to start/hard to keep running hamiamham Defender Technical Discussions 0 July 7th, 2008 10:19 AM
Running rich and now not running Big D Defender Technical Discussions 3 May 9th, 2007 01:58 PM
keep tearing pants getting into d-90 Campbell Misc. Chit-Chat 28 August 2nd, 2004 05:11 PM
