how do you get the lock out? - Defender Source
Old July 20th, 2012, 06:45 PM
apierce
Adam Pierce
'95 D90 ST #2395
I have replaced the door latches, but they don't come with new locks, so how do you get the old locks out?
Old July 20th, 2012, 07:32 PM
Remove all the bits attached then there is a little 'button' to press in which releases the lock from the mechanism.
Old July 20th, 2012, 09:17 PM
Lemonhead
TB
1997 D90 SW
This should help.
http://www.repairmylandrover.co.uk/d...el-replacement
Old July 21st, 2012, 01:12 AM
aaronlam's Avatar
aaronlam
aaron lam
1997 Alpine White D90 SW #2212
Not sure about the button... Mine had that little screw like in the diagram in the link above. I also had to take some of the cross brackets for the window regulator off to access the lock.
Old July 22nd, 2012, 11:32 AM
apierce
Adam Pierce
'95 D90 ST #2395
Thanks for the help. Still having trouble even accessing the lock because my locking mechanism doesn't have bolts like in the diagram, but rather factory metal stamps that i can't simply unscrew. I am going to try and drill them out today. Thanks again
Center Diff Lock Issues (on, off, or in-between) Heath Defender Technical Discussions 10 October 29th, 2017 01:39 AM
Line Lock for Winch Line Maine 110 The Vendors Loft 6 February 7th, 2006 06:47 AM
Door Locks Don't Lock ronward Defender Technical Discussions 3 August 27th, 2005 04:57 PM
RRC non-ABS: can you lock brakes? artm Defender Technical Discussions 1 May 30th, 2005 07:13 PM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
