How do I support Rover while changing axle? - Defender Source
Old May 31st, 2015, 12:21 PM
alecbeard
Alec Beard
1972 Series III
I need to do work on the front and back axles. Manual says "support the chassis". I can support in the middle of the car under the doors with jack stands. How do I support the front of the car? Of course the bumper and chassis are quite high off the ground. I've been told never, ever use cinderblocks. So how do I keep it up?
Old May 31st, 2015, 12:30 PM
Ray_G's Avatar
Ray_G
Ray Gerber
Jack stands on the front and back too (often on the frame near the axle housing or the axle housing itself, when you say work in the axle do you mean the axles themselves?
If you end up doing this a lot it may be worth grabbing a pair of jack axle stands from TSC.
Old May 31st, 2015, 12:33 PM
alecbeard
Alec Beard
1972 Series III
I can't support on the axle because I'm taking it out. Without the axle in the front, the only place to support is on the chassis near the bumper. Would I need to get a really tall jack stand?
Old May 31st, 2015, 12:50 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
You'll need some relatively tall Jack stands. I just pulled my rear axle out and you need enough clearance to pull it out (wheels off). Jack stands under the chassis in front of the rear axle and I had another under the hitch. Dropped the axle on a dolly and pulled it sideways.Click image for larger version
Old May 31st, 2015, 12:55 PM
Ray_G's Avatar
Ray_G
Ray Gerber
I think we need to be precise in our terms; you can pull an axle while supporting via the axle housing. If you are removing the entire housing then yes, you need tall jack stands-or wood blocks under normal jack stands going to the frame.
Old May 31st, 2015, 12:56 PM
Wilboro's Avatar
Wilboro
William Ficner
1997 110 csw
Indeed. I should have said entire assembly.
Old May 31st, 2015, 12:57 PM
Ray_G's Avatar
Ray_G
Ray Gerber
I would look at some of those TSC jacking jack stands on solid wood blocks and go to the frame near the bumper.
Old May 31st, 2015, 01:09 PM
DefenderMd's Avatar
DefenderMd
Ben
87 defender 110 3 door
throw your winch line up over a block hanging from a sturdy beam/tree and hook it to your rear xmember and winch.
Oh wait.. that is how to flip it on its roof.
down_shift's Avatar
down_shift
Russell
94' D90 ST & 06' LR3
Alec,
If you are new at jacking up a car and placing it on stands, I suggest having someone experienced with the process around to assist. A lot can go wrong, especially when working on more than tires and brakes. Just ~2 years ago we lost someone in the Rover community when crushed by his Disco in Richmond, VA.
Old May 31st, 2015, 01:24 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Originally Posted by down_shift View Post
Alec, If you are new at jacking up a car and placing it on stands, I suggest having someone experienced with the process around to assist. A lot can go wrong, especially when working on more than tires and brakes. Just ~2 years ago we lost someone in the Rover community when crushed by his Disco in Richmond, VA.
X2! Lost a cousin. Took 3 days. Terrible. Mitigate the risk with proper equipment and help the first time. It's just best to learn any risky process hands on from someone with experience imho.
Old May 31st, 2015, 02:00 PM
Nomar's Avatar
Nomar
Jeff B
RR HNTR,RR LWB Tdi
Yep, if you're not sure...ask someone with experience for help.
Greene County Man Dies After His Car Rolls Over Him
Land Rover=1 , Man=0
Alec, Ray and I have a Rover buddy in Free Union...perhaps he could lend you a hand if necessary...
Above all, be cautious!
Rent my
Old May 31st, 2015, 02:12 PM
Wheel chocks on the other axle plus e brake on to.
Old May 31st, 2015, 02:14 PM
don's Avatar
don
Don Bunnell
'86 110 3dr ST
I used some tree pieces I had cut into blocks. And some 4x6 pieces of timber to fine tune it.
I now have a bunch of leftover 6x6 timbers cut into 2' long pieces that I would crisscross now. If they are good enough to raise houses good enough for the D. Shook it a bunch to make sure it was stable. Check CL for people getting rid of old timbers. IMO - jack stands are way too squirrelly and unsafe.
Old pic from IG:
Old May 31st, 2015, 02:55 PM
87 D110 (Ruby)
you can (SHOULD) also use your tires...seeing they will apparently be off anyway...as another safety item under the truck.
Old May 31st, 2015, 02:58 PM
2x4's or 4x4's are fantastic for this purpose and not too expensive.
Old May 31st, 2015, 03:16 PM
D90Overkill
David Frank
1995 ST #2615
Exactly! Never set up a system to where a single point of failure is catastrophic. My back up usually has a back up! I know it's safety overkill, by life is too short to die young and badly! Good luck.
Old May 31st, 2015, 03:19 PM
DefenderMd's Avatar
DefenderMd
Ben
Yea, given the question and the ideas thrown around... just use all of them and maybe you'll be alright.
If you haven't ever worked around heavy equipment (or just unsuccessfully) and are lost enough feel the need to ask. Probably worth getting an on site second opinion. Your immediate family does NOT count.
Old June 1st, 2015, 07:47 AM
alecbeard
Alec Beard
1972 Series III
Who is this Rover buddy in Free Union? PM me if you want. Thanks!
Old June 1st, 2015, 08:14 AM
You haven't had the true Rover experience until one falls on you and busts a couple ribs.
axle
Tire changing while moving?!? WeBeCinYa Misc. Chit-Chat 0 January 14th, 2015 05:38 PM
Salisbury Axle with a welded on stub axle, disc brakes, Factory? Capt Milks Defender Technical Discussions 5 December 21st, 2010 09:45 AM
Series III Rear Axle (Drum-to-Drum or Axle Housing) Lriwater Wanted 0 September 7th, 2009 08:08 PM
Axle or axle casing Departing90 Wanted 0 May 29th, 2007 08:45 PM
While changing spark plugs mdmccallum Defender Technical Discussions 9 November 2nd, 2005 09:12 AM
