How do I remove a lock cylinder if I don't have the key? - Defender Source
Old May 1st, 2009, 01:04 AM
I did not get a key with my liftgate and I need to replace the lock cylinder. Do I have to drill it out or is there another way.
TYIA.
Ron
Old May 1st, 2009, 07:47 AM
if its like the other locks there is a small hole that you can stick a jewlers screw driver etc into and release the spring that holds the cyl in.
Old May 1st, 2009, 08:05 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
In a Rover one you have to have the key to turn it to the position that allows you to release the lock cylinder with a pick or small screw driver.
So you can either pick the lock to make it turn so that you can remove it, or drill baby drill.
Email:
Old May 1st, 2009, 11:02 AM
Viton's Avatar
Viton
Deaf Ember
Smart 4x4
By driilling the lock, you may inadverntantly tear somthing else up and end up having to replace more than the lock cylinder alone. I'd suggest you go to a locksmith & have a key fitted to the lock if it's just the key your lacking. Should you want a different key to fit the lock, the locksmith can re-arrainge the bitting parts (wafers) so the old key no longer works and the new one he creates will.
Dennis
Old May 1st, 2009, 11:16 AM
ECR's Avatar
ECR
Unless you drill too deep you can't hurt the Defender locks.
Been there, done that dozens of times... just did a rear door re-lock today.
Just take it easy and check periodically and you'll be fine.
Email:
Old May 1st, 2009, 01:45 PM
I did my liftgate years ago. seem to recall it was more complicated than the door locks, little annoying pins that were barely visible and had to be drifted out etc. but at some point I was able to change the cylinder as described.
I've had pretty good success picking the locks on these to get the old cylinders out. only had to drill one I think.
funny story I wanted an extra key for my SIII and ws killing time waiting for someone in the hardware store so I got the guy to try and match up a key blank to the LR one. We found a Mazda key that had the same end profile. But before cutting the key I took it out the truck to make sure it would go in the lock.
Not only did it go into the lock, it was able to unlock and start the car without even being cut...and it actually solved a problem I was having with the ignition switch where the heater would cut out once in a while until you jiggled the key. Hmmm, wonder what that profile was I kinda miss that truck
TYIA.
Ron
Ignition switch key lock revtor Defender Technical Discussions 5 December 4th, 2006 06:32 PM
Door Locks Don't Lock ronward Defender Technical Discussions 3 August 27th, 2005 04:57 PM
Dumb ignition/door key question, did search first Neo Defender Technical Discussions 15 May 30th, 2005 07:10 PM
110 roof, ignition key code, windshield frame, etc... martym Defender Technical Discussions 7 February 24th, 2005 01:45 PM
diif lock inquiry rover4x4 Defender Technical Discussions 16 February 6th, 2004 07:35 PM
