How do I get sound out of the radio? - Defender Source
Old March 18th, 2006, 06:29 PM
Gkase's Avatar
Gkase
George Kase
1983 110 200Tdi CSW LHD
Hi,
Well, I figured out how to wire the plugs and which plugs to get to install my stock Rover head unit...apparently out of a Discovery 1...anyway, the plugs were gotten from BestBuy and are stock for most German cars like Audi, VW, and Mercs...the kid behind the counter knew which one right away...$19.95...but, the radio doesn't make a sound once I plugged it all together!? Is there something I'm missing like a switch or something? I plugged in a Blaupunkt radio I had laying around and it works fine...I've got two Rover radios and neither work...any suggestions?
thanks
George
Old March 18th, 2006, 07:34 PM
The radios have a security code... Does the screen light up asking for a code? When ever I disconnect the battery, I have to reset the radio by entering the code. You may be able to bring the radio to LR, then they can look up the code. Or you may need the VIN from the truck the radio came from.
Hope this helps,
Old March 18th, 2006, 10:11 PM
Gkase's Avatar
Gkase
George Kase
code not the problem
it lights up and the code enters fine....stations on the display,etc, just no sound...
George
Old March 19th, 2006, 09:58 AM
johare
Jay
95 D90 White ST
I believe there is a stock amplifier under the passenger seat (mine does) is it working properly?
Old March 19th, 2006, 10:05 AM
sheki's Avatar
sheki
David Shechter
97' D90 SW 2.8L diesel
the new radio most likely has a built in amp, therefor you may have to rewire thing to bi-pass the LR amp, the speakers may be connected to the LR amp and not your new radio.
Originally Posted by MuddyOval
Sheki, you are a wang too.
A wang is another word for, you guessed it, A DICK!
Nothing racist, just pure DICK!
Old March 19th, 2006, 07:51 PM
johare
Jay
95 D90 White ST
I just did a complete rewire as the PO did a total hack job with the aftermarket stereo. Its now correctly wired but bypassing all the LR wiring was a real pain and took the better part of this weekend.
Jay
Old March 19th, 2006, 10:28 PM
Gkase's Avatar
Gkase
George Kase
Aha! Thanks for the tip...
I looked under the passenger seat...besides the fuel inject control and error code display, there was a CD changer! I've owned 3 other D90s before this but they were all 94s and had nothing under there but rust!...Thanks all for the help...there is no amp in there but there is this changer thing...I'll have to pull that out and refigure all the wiring...thanks again!
George
radio
Which Radio plugs work in 95 D90? Gkase Defender Technical Discussions 11 July 25th, 2011 12:41 PM
'97 Defender radio & changer setup? Defender50th Defender Technical Discussions 6 September 27th, 2005 11:22 PM
Fuel Pump Sound ronward Defender Technical Discussions 4 January 10th, 2005 07:45 AM
Electrical short with my radio ? paulb Defender Technical Discussions 4 August 11th, 2004 12:25 PM
Tapping sound from brakes? Cyborg Defender Technical Discussions 7 August 1st, 2004 08:57 PM
