How can you tell if the timing pointer is out of alignment? - Page 2 - Defender Source
Old January 15th, 2011, 09:54 AM
kevkon's Avatar
kevkon
kevin
1994 D90 300tdi #730, SIII 88
I didn't know this subject was so contentious
It's a free country, so everyone is entitled to pursue absolute TDC in any manner they would like. The only reason I posted was that Neil was looking for an answer regarding the timing on his truck. I assumed that was because he felt there was some problem regarding the timing which as it turns out is the case. The pinging or pre-detonation can be a symptom of improper timing ( too advanced). In a situation like this it is perfectly sound to adjust the timing ( retard) slightly to eliminate it regardless of what the timing indicator reads. Unfortunately today fuel octane ratings are suspect and even if one uses a high octane fuel from the pump you can still run into problems with pre-detonation, especially under a load.
Old January 16th, 2011, 12:36 PM
It's probably just me not knowing much about this, so please skool me. Why is it ok/recommended to disable the vacuum advance? Isn't the whole point to have a variable timing so that the advance can be different at idle than under load? Seems to me this is what Neil is facing, not some core TDC problem.
Originally Posted by pendy
I'm here for the D's
Old January 16th, 2011, 12:47 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
That's always possible too. If it's pinging under heavy load only, and not under normal operation. That the exact situation that the vacuum advance is intended to deal with.
-Hans
My oil line fix
My 100k stopped odometer fix
Old January 16th, 2011, 02:25 PM
kevkon's Avatar
kevkon
kevin
Remember there are two advances, vacuum and mechanical. I had a real vexing problem with a Lucas 45d where I was not able to get the timing right. While using the timing light I noticed some eractic timing. Took the distributor apart and found that the advance weights were hanging up due to years of dirt and corrosion. Sometimes it's just a simple thing that gets overlooked.
alignment
Cams, lifters, timing chains vesparover For Sale - Parts 11 March 10th, 2006 11:20 PM
Timing and Overheating mkerr2112 Defender Technical Discussions 10 July 6th, 2005 09:31 AM
Steering alignment kellymoe Defender Technical Discussions 10 November 19th, 2004 12:23 PM
Bonnet / Hood alignment jcasteel Defender Technical Discussions 1 November 6th, 2004 10:07 PM
