How bad is it? Need an assessment... - Defender Source
Old June 21st, 2012, 08:20 PM
ontheway's Avatar
ontheway
Dave
1986 RHD 110 SW OM617
Hey folks...
I'm in the hunt for a decent 110 SW and have come across one in particular that I like but has some rust issues. I won't be able to afford body work for a while - so I am looking for an assessment on how long the body will last without repair, how hard it would be to repair, and how bad it is relative to others you have seen. Thanks!
https://picasaweb.google.com/1074364...ots?feat=email
Old June 21st, 2012, 08:29 PM
Jackie Treehorn's Avatar
Jackie Treehorn
A
1985 (legitimately)
are those LPG tanks in the rear?
It's extremely hard to tell with photos (especially with generous coating of Waxoil). You need to dig around with a screwdriver to really see some shady stuff. That said, nothing looks completely gone from the photos, but if it passed a recent MOT that may be a good sign. UK is pretty strict about structural issues and soft frame parts.
Old June 21st, 2012, 09:15 PM
I'd give it 10 years or so depending on your ability to tolerate pain and suffering. And the amount of road salt they put down in your part of the world.
Originally Posted by ontheway View Post
Hey folks...
Old June 21st, 2012, 10:28 PM
texrover's Avatar
texrover
Jason
From looking at tiny pics in my iPhone doesn't look that bad and you're in GA so you won't add too much to what's there
Would be better to have pics of footwells, doors (behind the door cards) crossmember and door sills.
2003 RR L322
1971 Series IIA
1983 110 SW (Incoming)
1994 D90 ST (PO)
Old June 21st, 2012, 11:24 PM
Figure some new t-pieces and that thing should last for a decade.
Old June 21st, 2012, 11:35 PM
It's a pretty low mileage truck, spent a lot of time on a private hunting reserve if I recall. Doors all need to be replaced, but everything else looked sorted (I've obviously seen it before).
------ Follow up post added June 21st, 2012 11:38 PM ------
You are correct sir.
Old June 22nd, 2012, 06:44 AM
ontheway's Avatar
ontheway
Dave
Hey guys - thanks for all of the input.
Old June 22nd, 2012, 03:14 PM
mattarm's Avatar
mattarm
Matt
1993 D110
Mine was way worse than that I and I drove it for 6 years (never garaged in midwest) before tearing it down.
Symptoms of a bad axle CV joint? Hans Defender Technical Discussions 16 April 6th, 2007 01:20 PM
Need Help For Bad Handling...(I mean BAD!) Cube II Defender Technical Discussions 18 July 7th, 2006 09:07 AM
CV joint gone bad? Hans Defender Technical Discussions 5 December 4th, 2005 04:24 PM
Tire carrier problem - bad threads Antonios Defender Technical Discussions 4 May 7th, 2005 09:15 PM
bad bad BAD noise rover4x4 Defender Technical Discussions 11 December 12th, 2003 12:44 AM
