How are Defenders on the highway? - Defender Source
Old November 19th, 2010, 05:49 PM
Mister Bean
Matt Cullen
Say, in comparison to a Jeep Wrangler (TJ) or Land Cruiser FJ60?
I've wanted a Defender for a long time and have recently been thinking more seriously about getting one. I don't imagine they're great on the highway, and that's fine. I drove many highway miles with my FJ60 and never minded it. However, driving my father's TJ on the highway was an awful experience; emergency stops were very difficult to handle, winding roads weren't much fun, and the rear end wanted to come around at just about any speed in the snow with any application of the throttle. The Defender 90 wheelbase is much closer in length to the Jeep than the Land Cruiser so I'm curious how they compare. Any thoughts?
I'm not sure if this is the right forum, I didn't see one that was specifically Defender, but not technical. If this is in the wrong place, feel free to move it mods.
Old November 19th, 2010, 06:02 PM
They're fine as long as you don't have a "death wobble" ... this was mine when I first got it. It no longer has it after I got an alignment and balance with new tires. Honestly, I find it quite comfy, if not a bit loud.
http://www.youtube.com/user/rijosho#p/u/10/qnQb7zRvKWs
Here's my channel if you want to see what we did last weekend. Fun times!
------ Follow up post added November 19th, 2010 06:12 PM ------
Honesly, this is the best deal around right now. SUPER CLEAN Defender.
http://www.defendersource.com/forum/...6&postcount=20
Old November 19th, 2010, 06:54 PM
newfD90's Avatar
newfD90
Chance
93 NAS 110
Hey Matt-
Come on down to Monument, and you can drive mine if you'd like. They all drive fine on the highway.
Chance
Old November 19th, 2010, 07:00 PM
Neil McCauley's Avatar
Neil McCauley
Neil McCauley
94 ST, 97 ST, 93 110
It's a blast as long as its running and your not driving up a hill.
Robert Deniro
Old November 19th, 2010, 07:07 PM
Oh yeah I assumed we weren't talking about uphill highways.
Old November 19th, 2010, 08:14 PM
bharris's Avatar
bharris
Brad Harris
1994 d90 300tdi "Nola"
loud....
my take for freeway travel: better than a Jeep worse than a Land Cruiser
ymmv
Old November 19th, 2010, 08:15 PM
IF youre crying about the TJ you might as well get a Land Cruiser
Old November 19th, 2010, 09:06 PM
Rocketman's Avatar
Rocketman
Scott Y
95 D90 SW, 2003 Disco II, 93 D110
They are fine on the highway. I drove my D90 between Arizona and Mass a total of four times. However, with a 15 gal tank and 15 mpg, you are stopping every two hours or so to refuel. You really want to pay attention to managing your fuel. On a couple of my trips, I got close to running out of gas because I bypassed stations with say 40 miles of fuel and then not seeing another station for miles, miles and miles. A GPS navigator with fuel station locations is great and very helpful. On an interstate you can start bumping into the speed limiter built into the fuel injection system, which can be annoying. The limiter is set at about 85-90 miles per hour. On my last trip I installed a second ECU as a backup, mounting using standoffs on top of the original in tool compartment. I picked the second one up on ebay and it is from a Disco. One difference is the limiter, I have never hit it yet; the Defender can go that fast.
By the way, I always get roughly 15 mpg, whether driving in soft sand, on an interstate, or around town.
Old November 19th, 2010, 09:21 PM
HeloBubba's Avatar
HeloBubba
Chris Murphy
'89 127 (D130), '16 LR4
Louder w/bigger tires and if you have an exceptionally "rumbly" drivetrain. Also, should you decide to lift it more than about two inches, a whole array of issues may/will probably follow due to the changes in geometry, necessitating money thrown at it to make it better. In particular, they get squirrelly at highway speeds without caster correction/longer radius/trailing arms, and maybe even get very rumbly under accel/decel without correcting driveline angles, adding double cardon driveshafts, etc.
As you may have surmised, I dealt with all this on one of my trucks. After all the corrections, however, it now drives like a Cadillac on the highway, even if it is huge.
Or, you can buy one, leave it pretty much alone, and it'll be great, although loudish. (Except uphill as mentioned, unless you regear it......also a result of all the aforementioned excesses. ) My newer purchase will not get all the craziness the first one did. It does, however, ride like a truck even though its littler. Oh yeah, and make sure you have and keep a good tire balance and alignment as Josh mentioned if you'll be doing a lot of highway driving.
Just get one and you (probably) won't regret it.
Murph
On a side note, Boulder, CO! Sweet! <CU-Boulder. Class of '93>
Chris Murphy
'89 D130SW
'86 D110 3-door
'89 D110SW
'16 LR4
Former:
'97 D90SW - SOLD SEP '14
'94 D90ST - SOLD MAY '13
D90s sold while assigned overseas. You're welcome America!
'06 Range Rover Sport Supercharged
'8X FankenRover D100
Old November 19th, 2010, 09:41 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
If maintained meticulously they are pretty good, loud though. The tdi can be good if you drive more conservativly and with tuning will do 120-125kph all day. The V8 is a lot more fun and quieter (on highway, off-road or slow both do well) but you really want a 4.6l.
The one caveat is that if you lift one then you *need* to fix your castor or it will be more effort on the highway.
I also fitted a heavy front anti-roll-bar which makes any quicker manoeuvre much more predictable. Not 100% needed but I certainly prefer having it.
I also fitted the firm polybushes all around, koni heavy track shocks, and nearly every wear part is new or refurbished.
That all being said, I am now 90% happy with highway handling. What I still have left to do is to restore about 3 degrees of castor to get some self centering back. The reason I am doing this last is that it also tends to hide other issues like worn parts, by having the castor out every little issue is evident.
So, they can be kinda bad if worn like anything, but with time and attention they can be as nice as any double live axle vehicle can be.
(Can you tell I had spare time in the 110 waiting on picking someone up)
Old November 20th, 2010, 10:13 AM
hillstrubl's Avatar
hillstrubl
Danny
2005 Disco 3
Originally Posted by bharris View Post
loud....
ymmv
agreed
Originally Posted by Rocketman View Post
....However, with a 15 gal tank and 15 mpg, you are stopping every two hours or so to refuel....
my TDI is what really puts it ahead of my CJ or TJ on the highway, I only have a ~12 gallon tank, but I can still go further than my TJ did with a 19 gallon'er. One of these days I'll save up for an aux tank (when I eventually do a WVO conversion) for some serious range.
~2005 Disco 3 "Moneypenny"
~2008 GTI TSI
Old November 20th, 2010, 10:28 AM
discotdi
Todd Miller
Land Rover
I think a D90 is better on the hwy than an FJ60 or 62 but not as good as the 80 series and above. Long wheelbase of the LC helps it but the leaf springs suck when you hit the bumps if they are worn.
A defender 110 drives great on the hwy.
Old November 20th, 2010, 11:23 AM
zeusdavis's Avatar
zeusdavis
Jeff Davis
95 D90 ST 2006/3000
Just drove from Denver to Dallas and back in a soft top. Very loud. Wore ear plugs and saved myself a headache. Got anywhere from 11-13 mpg depending on wind direction. Ran out of gas once. 90 mph with tail wind. Max 65 mph with strong head wind. Have 33 inch tires, 2 inch lift, and roof rack. Rack actually cut down on noise....flooring seemed to redirect the wind from bouncing the top up and down. You can test mine if you're ever in Denver. Buy it for the mountains and tooling around town. Get a Range Rover for highway.
Old November 20th, 2010, 11:52 AM
61rover's Avatar
61rover
John Crouse
More comfortable and better ride than my Discovery II......
Old November 20th, 2010, 01:09 PM
specops1526's Avatar
specops1526
Beluga '97 90
Out of curiosity Horsey, how do you know this is the best deal and that it's "SUPER CLEAN"? Have you actually seen it in person?
Beluga 97 D-90
Chawton 04 DII SE
Tangiers 04 DII G4
Old November 22nd, 2010, 03:24 AM
Mister Bean
Matt Cullen
Thanks for the info everyone. Now I just need to convince my wife to let me trade a money pit Saab for a money pit Land Rover.
Newf and Zeus - I may take one of you up on your offer. Though it will be a little while.
Helo - It's a great place to live.
Old November 22nd, 2010, 08:03 AM
I will put in a gratuitous plug for a mid 80s-93 Range Rover. It will do just about anything you can do in a Defender but not beat you up in the process.
Old November 22nd, 2010, 09:54 AM
newfD90's Avatar
newfD90
Chance
93 NAS 110
LOL. Anytime Matt, anytime. I've got three different examples, all with different power plants. We keep going back and forth about selling the 90, but dangit, I know we'd miss her once she's gone.
Chance
Old November 22nd, 2010, 10:18 AM
the longer the wheel base the better the ride.
Old November 22nd, 2010, 10:28 AM
tjfslaughter's Avatar
tjfslaughter
thomas
Burbon
Thats what she said.
New and Old Defenders Grassroots311 Misc. Chit-Chat 19 May 10th, 2005 02:12 PM
Is KBB just way off on the going rate of Defenders? SpicoliWouldGo Misc. Chit-Chat 12 May 3rd, 2005 04:01 PM
Copley Defenders on eBay boshea Misc. Chit-Chat 11 March 9th, 2005 08:37 PM
97' not downshifting when at highway speeds... P1CR Defender Technical Discussions 3 December 12th, 2003 09:26 AM
Taliban Steals Charity Defenders wicks Misc. Chit-Chat 1 December 11th, 2003 06:12 PM
