Hot wire somewhere - Defender Source
Old September 18th, 2005, 06:19 PM
waveridin1959's Avatar
waveridin1959
Brian Jones
1995 D-90 ST #2892
Hot wire somewhere
I think there is a short somewhere in the electrical system. I have been melting teh ends of the brake light bulbs every month or two and around the same time I melt teh fuse to the rear lights/gauges/turn signals. When the fuse is start to go, the relay buzzes real loud for the signals and when I press the brake pedal I can see my gauges fall. The fuse is the right size and if you look at it close up bubbles are in the plastic where the plastic is melting.
1995 Defender ST
1996 Discovery SE7
2008 LR3 HSE - Wife's
Old September 18th, 2005, 10:31 PM
OK someone need to find the ground for the lights, I know of 2 Defenders localy that have goofy problems with the breaklights and the turn signals ad I am almost positive that it is something to do with bad grounds.
Hot Wire a D90 The Wizard Defender Technical Discussions 23 February 5th, 2009 09:42 PM
Needed: Coil Wire Hans Wanted 3 January 27th, 2005 10:19 AM
Portable Wire Feed Welder chrisvonc For Sale - Parts 10 January 5th, 2005 01:22 AM
