Hot Wax / Crayon Smell - Defender Source
Old March 6th, 2015, 05:11 PM
D110
Jamie
1955 107
Just recently our 1997 NAS 90 has started emitting the strong smell of hot wax/crayons from the engine bay after it has heated up - I've checked the exhaust to see if I had picked up a plastic bag or something, but can't see any signs of one. No obvious leaks, all the fluids are full. Anyone else ever encountered this? Any thoughts?
Old March 6th, 2015, 05:33 PM
1of40's Avatar
1of40
1of40
NAS 97SW & 83 One Ten Tdi
Battery cable over heating? Do you have a winch? If so, are the electric cables touching the exhaust somewhere?
Old March 6th, 2015, 05:35 PM
phoenix37's Avatar
phoenix37
john
check to see one of your breather tubes isn't melting against something...
NPT90's Avatar
NPT90
JT
D90 óriginalé
Check the O2 sensor wires as well, sometimes they rub
Old March 7th, 2015, 12:29 PM
CMSgt Bo's Avatar
CMSgt Bo
Bo
1985 One Ten
And check the throttle cable and make sure it's not laying against the engine somewhere. Mine has done that.
Proud member of the YCHJCYA2PDTHFH club.
My mechanic told me, "I couldn't repair your brakes, so I made your horn louder."
Old March 7th, 2015, 02:34 PM
You didn't take Madonna to see 50 shades?
Old March 10th, 2015, 12:31 PM
D110
Jamie
1955 107
Thanks for the suggestions - I poked around some more and finally found the culprit - the heat shield above the catalyst on the driver's side had broken loose and was resting right on top of the catalyst - probably had soaked up some waxoyl over the years.
Wax/Tin Cloth Land Rover hats josh-man The Flea Market 199 October 19th, 2016 06:28 AM
FS:Land Rover Wax Canvas Cap and Winter Toque mpodgorski The Flea Market 11 December 5th, 2015 03:01 PM
Wax preferences Landyman1 Defender Technical Discussions 9 May 25th, 2013 09:17 AM
can anyone recommend a good wax? Caribsurf Defender Technical Discussions 15 April 9th, 2007 05:39 PM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
