Hot Water shower - Defender Source
Old March 31st, 2007, 01:36 PM
andyrad
Andy Radlgruber
None.
Hot Water shower
Has anyone used a heat exchanger like this for an on board hot water shower. It is quite small and the entire system would fit quite nicely under the passenger seat.
Some people are so heavenly minded that they are NO EARTHLY GOOD!
Old March 31st, 2007, 04:26 PM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
That is too much work for me plumbing wise. I think you could fit it easier under the hood either in the fender or by the firewall. Good idea, though. How much are they?
Old March 31st, 2007, 04:33 PM
Shane@EVS
Roverhybrids
I use those style heat exchangers for vegetable oil conversions. That looks like a 40 plate and would work awsome for a shower. You better put in a valve to control the coolant flow, cause it could get to hot!
Old March 31st, 2007, 07:13 PM
andyrad
Andy Radlgruber
None.
Thumbs up
I already have a totally useless aux heater under the seat with coolant lines to and from. It's a no brainer. There's room under there for a 12 volt pump and the power is already there for the heater fan. The switch is next to the dash panel dimmer. I was going to mount hose fittings on the kick panel behind the passengers legs under the seat. Run a garden hose from the creek, through the pump, through a Y. One side goes through the exchanger and back out to the hot side of the shower tap, the other side goes straight to the cold side. Voila, hot and cold running water from under the passenger seat. A hot shower is soooo nice in the bush. This exchanger is a 30 plate and is about $100 on ebay. I can get a 350 GPH pump from Princess Auto, a great Canadian institution, for about $90 CDN. The rest is garden hose, hose clamps, and a trip to Home Depot for the shower part. When you said to install a valve for the coolant flow, did you mean because the water could get too hot or the exchanger? If it was about the water the standard tap setup will allow temp control of the water. I could easily install a diverter system to bypass the exchanger if need be.
Old March 31st, 2007, 10:58 PM
How about a link or search term to an exchanger on ebay? All the onboard shower exchanger systems (US and Aussie) run around $400. $200 in parts sounds a hell of a lot better. I have been very interested in this type of config, as anything to get the wife camping is money well spent.
Disregard request. I found the appropriate search term and can see them now.
Old April 1st, 2007, 12:46 AM
andyrad
Andy Radlgruber
None.
I think my wife may venture out with me again as well. Even if it ends up costing 359 after all is said and done it will still be a better quality setup than anything you can buy as a kit.
Old April 1st, 2007, 07:21 AM
GaryBaxter's Avatar
GaryBaxter
Gary Baxter
I am amazed at the creativity I see on this board and this is a great example. When you figure out how to incorporate a flush toilet and an outlet for a hair dryer, let me know. Those are my wife's requirements for joining me in my adventures.
Old April 1st, 2007, 10:59 AM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
I figured it out Gary. In order to get my wife out camping I had to get one of these: http://jaycorvs.com/jayco/baja.asp. It has a shoilet (shower toilet combo), outlets and a king and queen size bed.
Oh, and mine is in camo.
Old April 1st, 2007, 11:02 AM
JBurt's Avatar
JBurt
Jesse McCoy
'89 RRC SWB (needs work)
An inverter should take care of the hair dryer, and a 5 gallon bucket with a toilet seat and cover feels an awful lot like a flush toilet.
"It's not a Jeep"
Old April 1st, 2007, 11:23 AM
andyrad
Andy Radlgruber
None.
Isn't that just a tent trailer with a spring over conversion?. I'd still put on a set of 35's with spare axles underneath for backup.
Old April 1st, 2007, 11:44 AM
I have one on my truck... It works very well when you are camping for a couple days, and need to wash off. I will post a few pics when it stops raining.
Old April 1st, 2007, 07:57 PM
mdmccallum's Avatar
mdmccallum
'97 Defender 90 SW
Yeah pretty much. My in-laws sell them, so the price is right. Your right though, i should look into some 35's and a spare axle and a wench while I'm at it.
Old April 1st, 2007, 10:13 PM
andyrad
Andy Radlgruber
None.
I know a couple guys with Suzukis with Toyota axle conversions and they tow trailers with complete Toyota axles on them, hubs , 3rd members, axleshafts, and all. Comes in handy though quite an expensive utility trailer.
Old April 1st, 2007, 10:46 PM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Here ya go!
http://bumperdumper.com/
Old April 2nd, 2007, 08:38 AM
andyrad
Andy Radlgruber
None.
Originally Posted by Stmpede
Now that's thinkin'
Old April 3rd, 2007, 12:11 AM
chris snell's Avatar
chris snell
Chris Snell
87 Ex-MOD 110
So you're going to shower off with creek water? Might work nicely in the mountains but out here in the desert, the last thing you want to do is shower off in some mank creek water--if you can find a creek!
Seriously, where do you use these?
1987 Ex-MOD 110 Tithonus LHD
2013 LR4
Old April 3rd, 2007, 01:02 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
Just run it through a brita!
Old April 3rd, 2007, 08:38 AM
andyrad
Andy Radlgruber
None.
Lightbulb
In the mountains. I must admit I've never been camping in the desert. After a few days in the mountains in summer you're covered in bug spray and sweat, you stick to your speeping bag, and you start to smell good to grizzlies. The creeks are damn cold and so are the lakes. We do have hot springs but too many people use them for soaking so there will be no hot baths in there. On board hot water is the only way to go.
water
water pump gasket kolvedic Defender Technical Discussions 2 September 11th, 2005 08:22 PM
Help - Stuck in water for 3+ hours mfreeman17 Defender Technical Discussions 2 May 25th, 2005 08:10 AM
Water leak Jon D' Defender Technical Discussions 1 September 5th, 2004 08:34 PM
