hot stumbling, stalling.. (continues) - Defender Source
Old July 11th, 2008, 05:11 PM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
(I wish I could post happy summer adventure stories...)
any good mechanics in NJ/PA/NY/CT? who do you bring your truck to?
Guys, I got my truck back from the shop.... they had it for two weeks, ended up installing new parts galore (replacing the ones I recntly installed).. but my problem came back one day later. After they said it was all good. What should I do. Any good mechanics in NJ/PA/NY/CT? Anyone want a stab at this? I'm done with it and I dont really feel like dropping it off with the same guys again. I will call them of course, but I dont want them to just throw parts at the damn thing anymore.
problem:
When my engine gets up to temp and has been running for 10-15 minutes, it stumbles off idle, and wont hold idle for more than 20-30 seconds.
New dist, vac advance, temp sensor, idle stepper motor, coil, fuel filter. Im going to get a vac gauge and check it cold vs hot.
I got an HEI distributor from HEI Dizzy (ebay) and my mech said no way it will fit. I knew it would require grinding and a bit of f-ing with but they were having no part of it. Anyone on the board install one of these? I'd love to get rid of more Lucas.
sorry to rant and bitch but I'm so ready to get rid of this thing.
~Steve
Old November 4th, 2008, 11:04 PM
xrover's Avatar
xrover
Len Cater
1997 D90
Figured I would reply to this one, since I just had a stalling issue. Checked the usual suspects (no thrown codes, fuel pressure good etc). What it appears to have been is a sticky throttle. Easier to show live, but try and visualize this. You come home at night and turn off the truck. The throttle does not go back all the way and instead sits 1/8" from full close due to it sticking. In the morning you start up the vehicle (I never touch the throttle when starting), so now the throttle position and maf calculate fuel and air based on this 'starting' position. You hit your first light and everything is fine (still running a bit cold). Get on the highway, and now when you pull off and stop at the next light, the throttle position moves back to fully closed, which is now further than it's "starting" position, and the truck idles down and stalls. She'll start fine. So after lubing the springs and the cables and leaving some slack in the idle adjustment, she's running fine with no stalling. And it cost nothing (assuming you already own a can of lube).
Hopefully yours is that simple.
'97 D90 NAS
'06 Argo Avenger
Old November 6th, 2008, 10:27 AM
Tim Scully's Avatar
Tim Scully
Tim Scully
95 D90 SW/ 95 RR LWB
So many things can cause these problems. Have you replaced the cap, rotor and ignitor. Do you have the ignitor relocation kit that puts it the ignitor by the coil??? If you replace the cap and rotor make sure you use factory stuff not aftermarket...
Old November 6th, 2008, 11:31 AM
revtor's Avatar
revtor
Steve Maietta
1969 IIA 88" Bugeye
Truck has been sold.
Old February 10th, 2009, 01:27 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
Interesting concept, I'm suffering from a similar problem myself so I'll look into it.
My oil line fix
My 100k stopped odometer fix
stumbling under load when hot..? revtor Defender Technical Discussions 0 May 5th, 2008 08:57 PM
stalling bjenk Defender Technical Discussions 5 May 7th, 2005 12:56 AM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Playing with Rovers, guns and a hot blonde in Africa wicks Misc. Chit-Chat 1 February 21st, 2004 09:31 AM
Superlift ORV Park in Hot Springs, Arkansas Nov. 20-23 Joe B Trips, Trails and Events 5 November 12th, 2003 10:07 AM
