HOT Bulkhead - Defender Source
Old August 24th, 2010, 08:42 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
HOT Bulkhead
My bulkhead - directly behind my panels on the driver's side- is getting HOT when driving for more than about 30 minutes. Is there something that I can do to make it not so hot? Should I have anything looked at or is this normal. It gets hot enough to warm up my feet.
Marcus
Old August 24th, 2010, 09:40 PM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Mine does the exact same thing. 100 degrees and open top rover make the heat baking my feet feel like ac!
Old August 24th, 2010, 10:47 PM
ajh
Andrew J. Hutton
1993 Defender 110 200TDI
You could add a heat shield to the outside surface between the bulkhead and the exhaust downpipe.
Old August 24th, 2010, 11:18 PM
bjf's Avatar
bjf
barry f
94 ST #395
my 110 does that but not my 90
Old August 25th, 2010, 11:44 AM
jefhuf's Avatar
jefhuf
Jeff Huff
'94 D90 ST #655
I think there are a bunch of threads about heat shields and/or adding Dynamat or something similar...I know that on a 95 degree day traveling at highway speed across Rt 66 we checked the bulkhead temp with a digital thermometer and got readings in excess of 130 degrees!
My first step was adding thicker floor mats!
Old August 25th, 2010, 11:50 AM
Opening the dash vents will suck the heat up out of the footwells. I always keep them open on hot days.
Old August 26th, 2010, 02:32 PM
GMFett's Avatar
GMFett
Marcus
1994 D-90
I meant to say behind the pedals- not panels. The floor doesn't get particularly hot.
Bulkhead Rust TurkD90 Defender Technical Discussions 4 May 14th, 2005 05:06 AM
For Sale Bulkhead removal bar TDI Guy For Sale - Parts 11 February 2nd, 2005 08:57 AM
Bulkhead Questions JimC Defender Technical Discussions 19 October 27th, 2004 01:00 PM
bulkhead removal bar Chris Cox Defender Technical Discussions 0 August 22nd, 2004 12:13 PM
Help with installing bulkhead on chassis Chris Cox Defender Technical Discussions 2 June 5th, 2004 09:33 AM
