Hot-Boxed my 90: Blown Heater Core? - Defender Source
Old September 27th, 2014, 05:18 PM
rtgoldenb's Avatar
rtgoldenb
Tyler
1997 D90 NAS
So I just hot-boxed my 90. I haven't been running ac or heat for a few weeks since the weather has been close to bearable in NOLA, but i moved the temp control down to the red and the entire cab filled with stinky hot steam. I pulled over and noticed that there pints of anti-freeze dripping from the what appears to be the heater core. There wasn't much spray inside the engine compartment, so the leaking is coming from the inside the heater core box.
Part?:
I am assuming that the cause is a blown heater core, but is it possible that it could just be a hose(s)? The fan definitely still blows since it was force feeding me Martian style steam.
Access?:
I did read the below thread, but couldn't gather the best way to access the core, so any advice on that would be great.
http://www.defendersource.com/forum/...eferrerid=8747
Replacement?:
I was going to buy (http://www.roverparts.com/Parts/STC250K), but then i saw the Allisport reference in the above post and wanted to know if that or any other afte amrket upgrade is a better idea than going stock. Price isn't really a concern, as I hope to not have to do this again in the near future:
I have never been inside the box before and I'm in uncharted territory, so any help or guidance would be greatly appreciated.
Tyler
Old September 27th, 2014, 05:32 PM
By pass the core by removing the 2 hoses and join them with a short length of 3/4 pipe.
I don't think there are benefits to any special cores ... a radiator shop can probably rebuild yours or a new one is gonna be needed.
The removal isn't particularly difficult and some improvements can be made by making sure everything seals nicely when you put it back together.
Old September 27th, 2014, 05:36 PM
Angus's Avatar
Angus
Mike Ferguson
1994 Defender 90
Tyler,
I had the same thing happen on my 94 earlier this year. Replacing the core is a bit of a job, but not difficult. I doubt it would be the hoses, mine are outside the heater box. My core had plastic end caps, and one split. You have to remove the box itself to get to the core. There were a couple of bolts with nuts that are under the A/C eval/vent unit, which required me to remove it. I replaced them with riv-nuts so that will not happen again. Then you can pull the box out enough to get the core out. Be sure to bleed the air out of the core once done or the heater will not get very hot.
I am sure there will be a lot more help offered when folks get back from the Expo.
Angus
Old September 27th, 2014, 05:52 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Sounds like your heater core went. Mine had a bunch of debris buildup at the bottom of the heater box which finally wore out the fins. AB sells the genuine core for around a $100 or so; it still does have the plastic inlet/outlet pipes but if the factory part worked since '97, Im ok with that.
Ive read on here that you may have issues attaching the hoses on aftermarket cores as the inlet/outlet pipes on the core are too close together...no experience but for a $100 for the genuine, no brainer. No experience with the alloy models, they look nice.
So as alluded to, you have to remove, if installed, the AC fascia and gently push the evaporator/blower assembly off the rubber mounts towards the center console to get at two bolts midway up the passenger footwell that hold the bottom of the heater box.
Also remove all the crap on the passenger engine compartment wheelwell, and clean out the intake pipe. The drain on mine was plugged, again causing the buildup and demise of my heater box.
Other than that, pretty straight forward. Lots of little screws to remove to split the heater box. There are also a lot of foam bits in there that may or may not need replacing. I did not but will later, they add to the musty smells if not replaced.
Also search for Overlander's thread on port matching the heater box to the bulkhead for increased output. Theres also info on upgraded wiring to the blower and replacement GM blowers for more air.
I also replaced the hoses and clamps at the time.
There should be pics in those threads...deleted all off my phone unfortunately.
And as Leastonce said, connect the inlet/outlet hoses as a temp fix if needed.
Old September 27th, 2014, 06:31 PM
While you have it opened up, look at improving other things. http://www.defendersource.com/forum/...ad.php?t=30938
Old September 27th, 2014, 07:17 PM
rtgoldenb's Avatar
rtgoldenb
Tyler
1997 D90 NAS
Gents,
THANK YOU SO MUCH! This is all super helpful. My initial plan was to bypass the core and connect the hoses. Luckily I have a few months before I'll need to start thinking about heat. I'l probably buy the genuine from AB, but do you guys think its worth the $$ to have a shop do the work for convenience sake or do it myself to maintain quality control?
As always, thanks again,
Tyler
Old September 27th, 2014, 07:58 PM
SMac's Avatar
SMac
Sam
NAS 97 D90 SW
Originally Posted by rtgoldenb View Post
Gents, THANK YOU SO MUCH! This is all super helpful. My initial plan was to bypass the core and connect the hoses. Luckily I have a few months before I'll need to start thinking about heat. I'l probably buy the genuine from AB, but do you guys think its worth the $$ to have a shop do the work for convenience sake or do it myself to maintain quality control? As always, thanks again, Tyler
Do it yourself if you have the time. Id guess this would take you the cost of parts and 4 hours versus a $400-600 job for a shop. And you get to know a bit more about your 90. But we understand that sometimes our time is more valuable than wasting it on a Defender!
On those two bolts inside the cab, best to have an additional set of hands as they may be a bit rusty or at minimum some locking pliers to hold onto the bolt head.
Old September 27th, 2014, 08:35 PM
rtgoldenb's Avatar
rtgoldenb
Tyler
1997 D90 NAS
Sounds like the right plan, i think that's why i'll take the bypass shortcut until i can devote a weekend. I also think i can hear all my buddies rapidly filling their calendars, but luckily grandpa is always around to wrench.
Thanks again,
Tyler
Old December 1st, 2014, 08:37 PM
rtgoldenb's Avatar
rtgoldenb
Tyler
1997 D90 NAS
So after much anxiety and intimidation, I have decided to undertake replacing my heater core. But, as always, i have a few questions. (apologies for the length, just want to chronicle this thoroughly)
FIRST -- Genuine or Aftermarket? I typically don't think twice about this, but with such a massive price difference, I want to make sure the genuine is worth the price. (FWIW, George at RDS had a genuine that he was going to sell me for $260, but I was unfortunately too slow on that)
RN Genuine ($389.95)
http://www.roversnorth.com/ProductDe...de=UTP1725&eq=
RN Proline ($79.00)
http://www.roversnorth.com/ProductDe...=PLF414&type=0
AB Genuine ($359.95)
http://www.roverparts.com/Parts/UTP1725G
AB Premium Range ($99.95)
SECOND -- Hoses? This seems straightforward.
RN Feeder Hose ($20.06)
http://www.roversnorth.com/ProductDe...e=0&eq=&key=it
RN Return Hose ($33.95)
AB Feeder Hose ($16.95)
http://www.roverparts.com/Parts/AWR6631G
AB Return Hose ($31.95)
http://www.roverparts.com/Parts/AWR6632G
THIRD -- Foam? Does anyone sell specific replacement foam or is this just local hardware foam?
FOURTH -- Enlarging bulkhead hole. Is it worth cutting into the bulkhead as described in Overlander's thread below? I plan on having this truck until I die, but I do like the idea of keeping it "stock" and cutting into the bulkhead almost seems taboo.
FIFTH -- DefenderVENT? Similar to the bulkhead cutting, its it worth cutting into the dashboard panels? Also, how difficult is this install?
http://www.mudstuff.co.uk/defendervent.html
SIXTH -- Heater Fan Upgrade. I think this may be above my level of expertise at the moment, but these are the threads I was looking at regarding blower upgrades. If this is in fact easier than it looks, please chime in.
http://www.defendersource.com/forum/...ht=heater+core
http://siteground237.com/~gunsandr/showthread.php?t=321
http://www.red90.ca/rovers/Heater/heater.html
Lagniappe -- Beyond the workshop manual, these are the other resources I am referencing:
http://www.defendersource.com/forum/...ad.php?t=27684
http://www.defendersource.com/forum/...ushings&page=5
http://landytown.myfastforum.org/Def...about1383.html
http://forums.lr4x4.com/index.php?showtopic=40566
As always, any advice or guidance is much appreciated.
-Tyler
Old December 1st, 2014, 09:17 PM
All the non-genuine are likely from the same place. I used non genuine in mine about 4 years ago and haven't had any issues. Just make sure it's not damaged before it goes in.
Broncoduecer's Avatar
Broncoduecer
peter
D90
Check out rovahfarm.com when you know the part numbers. I like to look at Allbrit.de because they have a pretty good parts diagram, but there are many out there.
Third - MRC8378 and STC953 are the foam pieces you will need.
Forth - I would do it since you are there. You probably won't be back in there for awhile. I did mine.
Fifth - if you want to get into the dash more then go for it! I also have one, but I already had my dash open. I hear good things but a lot of people say it's too expensive for what you get. Dave at urban landcruisers sells them stateside.
The old foam will probably be pretty crudy. Take some time and clean it up well and use a good adhesive to put the mrc8378 part on.
Old December 1st, 2014, 09:30 PM
rtgoldenb's Avatar
rtgoldenb
Tyler
1997 D90 NAS
Awesome, thanks gents.
Old December 1st, 2014, 09:55 PM
Trevor has the same heater matrix.Rovahfarm: UTP1725 / Price $62.95
For Foam, get closed cell neoprene medical type.
Some limited dollars to save if ordered direct from UK.
Old January 7th, 2015, 12:32 PM
I pulled my heater box out to replace the core and found at least a pound of mud and this:
Old January 7th, 2015, 12:38 PM
The leaking core:
Old January 7th, 2015, 12:49 PM
You don't need no stinkin' heater core in Phoenix! Rip the guts out and turn it into a manifold cooker for your snacks!
Hey, go through that stuff with fine toothed comb, just in case Maurice Wilks left a time capsule in there.
------ Follow up post added January 7th, 2015 12:50 PM ------
PS, if you have mud in your heaterbox, you're doing it right! Not like those Jersey metrosexual owners that focus on armor all'ing their boost wheels! No offense Boost Club!
Mark Kellgren
KM4BOR
Old January 7th, 2015, 01:27 PM
Bill Larson's Avatar
Bill Larson
Bill Larson
Ssshhh they never realize an insult unless you tell them...
------ Follow up post added January 7th, 2015 12:28 PM ------
Yeah that's crazy...
Old January 7th, 2015, 04:02 PM
roverman2010's Avatar
roverman2010
1985 LR 90 200Tdi
You found treasure Like the MOD issue AA battery
JnK Services
FC101 GS FFR
57 LR 88" SXF 858
85 LR90
95 D1 Tdi
05 D3 HSE
97 XK8 BRG FHC For Sale
90, heater
heater matrix heater core. Naplm00 Wanted 0 December 21st, 2011 01:34 AM
More boxed LR parts RockhoundVA For Sale - Parts 0 February 18th, 2011 02:18 PM
A/C Help......hot, hot, hot! boulderbear Defender Technical Discussions 7 August 26th, 2006 07:54 PM
Heater core ?? & FYI D90user Defender Technical Discussions 4 October 14th, 2005 03:27 PM
Heater core Burke Wanted 1 December 9th, 2004 12:21 AM
