Hot ac controls? - Defender Source
Old August 29th, 2010, 08:18 PM
Sun Traveler's Avatar
Sun Traveler
D. B.
110 Defender Tdi
Hot ac controls?
Hi today I noticed my ac control knob was feeling loose and upon inspection I noticed that the metal fan control that the plastic turn knob is attached to was hot to the touch.. almost hot enough to burn my finger? I turned off the ac and headed home to check it out,
-has anyone experienced this or have any ideas why it has become this way?
Old August 29th, 2010, 11:51 PM
I just had the same issue (still working a/c issues with manufacturer) with my main brown connector for the ac being too hot to touch. it ended up being a factory terminal in the connection that was never a very good contact and had too much resistance in the connection to due corrosion or something.
too high of resistance in a connection is what you should be looking for. our ac systems rely heavily on 12v negative signals. check your switch wires with a multimeter for resistance on the ohm setting.
Old August 30th, 2010, 12:22 PM
Sun Traveler
D. B.
110 Defender Tdi
Thank you for the advise, I will be working on it today. with it being 90 degrees for the rest of the week I hope I can resolve the issue..
Old August 30th, 2010, 05:21 PM
Sun Traveler
D. B.
110 Defender Tdi
I now have the fan speed switch removed and it is damaged, the red wire in the 7 oclock position was broken ( from the rear view).. there is some small burn look to the wire terminal sleaves.. I am not sure yet if this was caused by the fan switch becoming loose and then grounding or touching the other wires..
does anyone know where to get a new fan switch?
it says across the top of the back (INDAK)
I will check RN tomorrow..
Old August 31st, 2010, 10:44 AM
Sun Traveler
D. B.
110 Defender Tdi
I located the switch and part # and will be ordering one today, I have the option of using the steel with zinc coating like the origional or a copper post?
ac
Making AC Lines Lesandjes Defender Technical Discussions 3 July 10th, 2008 12:58 AM
Who's too hot? AC For Sale revor For Sale - Parts 3 June 5th, 2005 12:18 PM
Running Hot??? Burke Defender Technical Discussions 10 March 21st, 2004 02:33 AM
Playing with Rovers, guns and a hot blonde in Africa wicks Misc. Chit-Chat 1 February 21st, 2004 09:31 AM
Superlift ORV Park in Hot Springs, Arkansas Nov. 20-23 Joe B Trips, Trails and Events 5 November 12th, 2003 10:07 AM
