Hose replacements - Defender Source
Old March 14th, 2006, 04:26 PM
kolvedic's Avatar
kolvedic
Bill Lewis
1995 White SW 339/500
Hose replacements
I got my hose replacement kit and am getting ready to swap them this week. Anything I should watch out for? To drain the radiator, do I need to remove the lower hose or pump it out?
thanks,
Bill
Bill
Old March 14th, 2006, 04:50 PM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
You can drain it by just removing the hose, never found an easy way to drain it any other way set up as from the factory. While you have it out, Summit sells some inline drain plugs that go into the lower hose. Not sure if this is the right size, but it's the kind of part you want.
http://store.summitracing.com/defaul...=egnsearch.asp
Also, it does get easier if you lube the inside of the hose. Places sell dedicated lubes for it, I just normally use petrolium jelly.
My oil line fix
My 100k stopped odometer fix
ac
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Oil Cooler Hose Upgrade JimC Misc. Chit-Chat 6 October 15th, 2004 02:13 PM
97 low pressure A/C hose source dnewman9 Defender Technical Discussions 1 June 15th, 2004 01:39 AM
