Hose Help 2.5 NA - Defender Source
Old June 19th, 2016, 05:40 PM
ghoregon
Greg H
1984 Defender 90 Ex-MoD
Hose Help 2.5 NA
Hi all and Happy Father's Day if you are one.
Looking for help on the little hose that goes between the water pump and the thermostat housing on the 2.5 NA. I picked up an ERC 5654, but it seems too narrow. The existing hose has an OD of about 43mm whereas the new one is closer to 39mm. Anybody else have this issue and if so, the appropriate part number for the hose?
I guess I can just buy some bulk hose
locally if need be, but trying to keep things at British as possible (within reason of course). :-)
Greg
Sent from my SM-G920P using Tapatalk
Old June 19th, 2016, 06:55 PM
rdavisinva's Avatar
rdavisinva
Robert Davis
N/A
The hose should be no problem to expand that far.
I think you'll find it will fit and stretch the 4mm easily and even easier if you leave it in the direct sun...
RDavisinVA
Old June 19th, 2016, 06:58 PM
ghoregon
Greg H
Ah...thanks Robert. Didn't realize these hoses have that much room to expand. Appreciate the help!
I need help with the brake booster vacuum hose routing Chip Defender Technical Discussions 0 August 30th, 2012 12:52 AM
Fuel Hose...yep hose. wcampbel@nas.edu Defender Technical Discussions 0 January 9th, 2012 05:22 PM
2 inch flex hose help MUDSUX Defender Technical Discussions 7 February 19th, 2010 09:16 AM
Air intake hose, fuel filler hose and neck SafariHP The Vendors Loft 0 May 18th, 2008 08:52 PM
quick help on heater hose routing! kevincdoyle Defender Technical Discussions 16 February 21st, 2007 05:35 PM
