Hose blows - Defender Source
Old September 11th, 2013, 12:43 AM
california
Geoff M
Hose blows
I drove my truck up into the hills (of Hollywood) on a really hotbday and when I stopped the big hose leading into the Pleneum (if that's what it is called) blew up creating a huge steam cloud. I thought my truck was on fire for a minute.
I fixed it with a steak knife cutting the end off that blew and adding water, which got me home. Driving home the temp went way up then stabilized at the middle.
Generally, My truck seems to run hot... It always feels crazy hot. But I have not done the fix on the gauge, and the stock gauge just stays in the middle.
I have read lots of the overheating threads and threads that talk about things close to this, but nothing exactly like this blown hose.
1993 nas 110 75k miles seems to have endless problems
Any thoughts where to start? Thanks in advance
Old September 11th, 2013, 03:30 AM
Old hose? I would start by changing them all out. It's a lot cheaper than a new head gasket and all the involved machining.
Old September 11th, 2013, 04:07 AM
While your at the cooling hoses, don't forget hoses to the heater matrix as well. Is it time to rod out the radiator?
Old September 11th, 2013, 11:53 AM
california
Geoff M
Ok. Yeah, the hoses do appear original. I was going to order a full set.
Is there a way to tell if a radiator is worn out? I am sure it is original too.
Old September 11th, 2013, 12:05 PM
Twenty years old.... I would just replace all the hoses, the radiator, thermostat and fan viscous unit.
Old September 11th, 2013, 09:47 PM
california
Geoff M
I grew up in NW Calgary
Old September 11th, 2013, 09:59 PM
geoellis's Avatar
geoellis
George
1995 D90 #2904 - BB
Completely agree. My truck was running hot at around-town speeds. The radiator fins would crumble when you touched them and the whole system looked original. I replaced every hose in the engine compartment, radiator, fan clutch, thermostat and sensors. The water pump is newer as well. Problem solved and it's nice knowing that all cooling components are new and solid.
1997 P38 4.6
1998 P38 4.0
2011 LR4
Old September 11th, 2013, 11:13 PM
Great idea to baseline the cooling. Hoses, water pump, fan clutch, radiator, radiator cap if its not new, replace it. It is not that expensive (less than a grand in parts). I run a 180 degree thermostat as well. If the sensors are not acting up (easy to check) I would leave them.
Hose replacements kolvedic Defender Technical Discussions 1 March 14th, 2006 04:50 PM
What size is the lower radiator hose? Hans Defender Technical Discussions 2 February 11th, 2006 06:29 PM
Stupid vacuum hose Mike Hippert Defender Technical Discussions 7 November 9th, 2005 09:00 PM
air intake hose?? / source for cheap switches NASD90 Defender Technical Discussions 15 July 6th, 2005 02:40 PM
Oil Cooler Hose Upgrade JimC Misc. Chit-Chat 6 October 15th, 2004 02:13 PM
