Horn Switch Access - Defender Source
Old September 23rd, 2011, 02:38 PM
Horn Switch Access
Hi folks,
On the turn signal stalk, how do I open the stalk to gain access to the horn switch?
Basically, there is an end-cap to the stalk that you push to actuate the horn. The switch is contained within the end-cap, but I cannot remove the end-cap.
I disassembled the turn signal switch and the solution to the problem does not lie within the turn signal part of the stalk. It is located underneath the end cap.
Old September 23rd, 2011, 10:30 PM
Figured it out. Can be pried gently using a large flathead between the gap of the large part of the stalk with the endcap.
You must pry a very small amount on each side of the gap evenly.
ac, horn, switch
Wiper motor limit switch replacement LenB Smaller Projects 5 June 7th, 2012 07:29 AM
DIP, Horn, Directional Switch for 1997 NAS Defender 90 Waldo For Sale - Parts 1 July 13th, 2011 09:31 AM
P/N for heated windshield switch mgrgpg Defender Technical Discussions 5 November 12th, 2004 08:19 PM
