Horn relay? - Defender Source
Old June 4th, 2016, 05:02 PM
scrubs
henery
1974
Horn relay?
Hi, would like to get non-working horn back working pulled horn from a MB 300d.
MB Horn works fine when attached to battery tho makes a clunk sound when wired through the 110.
Would a relay be needed or is something else wrong
Don't have a meter to test how much juice is going through wires.
Old June 4th, 2016, 05:08 PM
A relay is a good idea especially if it is a high draw item. From what you are describing it is a high draw item.
Old June 4th, 2016, 06:05 PM
scrubs
henery
1974
Yehaaaaaaaa, lol, took a few minutes, relayed now n works fine, should've tried before askin,
Thanks for reply
horn, relay
D-90 air filter housing cap needed (horn) arbik Wanted 4 November 30th, 2010 12:45 PM
louder horn advice chirider Misc. Chit-Chat 9 April 8th, 2008 04:49 PM
Wanted: SW Roll Cage RH "horn" or POE "horns" JimC Wanted 8 December 5th, 2006 03:35 PM
Frame horn measurements D90 KevinNY Defender Technical Discussions 0 October 31st, 2006 02:58 PM
Fuses? Horn and clock... OCD90 Defender Technical Discussions 3 November 17th, 2003 06:05 PM
