Horn not working after 200TDI Swap - Defender Source
Old April 18th, 2016, 04:43 PM
LakeLBJ
CC
SOLD - 1987 D90 LHD / 200TDI
So I am putting the finishing touches on my 200TDI swap. (87 90 LHD) Last night I was putting my front panel and radiator shroud on. Before I put my grill on I remounted and plugged in my horn. Went to test it, and no go. First I checked the fuse and noticed it was burnt out, so I replaced it thinking that was an easy fix. Unfortunately that didn't fix it. Everything else on that same indicator stalk (turn signals, high beams) works just fine. Any thoughts? Could I have missed a ground somewhere that needs connecting?
Old April 18th, 2016, 08:32 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
My horn needed 2 wires. +12V and a ground. The case wasn't grounded. Did you hook 1 wire or 2?
Old April 18th, 2016, 08:36 PM
Brewie212's Avatar
Brewie212
Brian Kandefer
Did you test it with a test light to see if you are getting power?
Old April 18th, 2016, 08:49 PM
LakeLBJ
CC
Just one wire.
Old April 18th, 2016, 08:51 PM
steinhnj's Avatar
steinhnj
Neil Steinhagen
1990 Perentie GS
Check your horn again. Does it have 2 - 1/4" male spades or just 1?
And do what Brewie said, hook up a meter to the wire you connected and see if you get 12V when you sound the horn.
Old April 18th, 2016, 09:02 PM
Or leave it...if they actually hear it over the clack of the motor, and then after they stop laughing, my wife and daughters expect clowns, unicycles, monkeys, and trapeze artists to start pouring out of the truck whenever I press the horn.
Old April 18th, 2016, 09:09 PM
Daddymow's Avatar
Daddymow
Raub A.
1987 D110 Tithonus
Too funny! Same thing here, after my 200Tdi swap my horn no longer works. Weird. Like spooky weird. So now I ride around and give everyone the middle finger. Even my neighbors when they wave.
Old April 18th, 2016, 09:18 PM
LakeLBJ
CC
I like all the anti-horn suggestions, sounds like some good times. I just don't think it will pass inspection in Texas without it!
I tested the plug with a multi-meter while my dog honked the horn and didn't seem to get any power.
Photo of connection attached...
Edit: Hmmm...maybe one connection fell off...
Edit 2: Went back out and checked under the wing, there is only one wire coming off that connection with the headlights and turn indicators for the Horn that I can see.
Old April 18th, 2016, 10:14 PM
solarguy's Avatar
solarguy
Abraham Bell
1985 Defender 110 Tithonus
Well I guess I will add to the list. Mine didn't work after I did mine. The terminal broke off of the horn.
Old April 18th, 2016, 10:15 PM
Z.G's Avatar
Z.G
Zack
300Tdi 95 D1
Looks like corrosion took one of your terminals
Old April 18th, 2016, 10:18 PM
Did you by chance change the turn signal stalk with a new part?
Old April 18th, 2016, 11:17 PM
RovingRyan's Avatar
RovingRyan
Ryan Phelps
84 LHD 110
I just replaced my oe horn from 84. Was a single wire and the horn was grounded through the stud in the center via the bracket. I have dual hella horns now. Very loud!
Mine is also a 200tdi conversion but my horn worked just sounded like a clown car for the last three years!
Ryan
84 110SW County LHD
07 L322 Vogue
Old April 18th, 2016, 11:38 PM
LakeLBJ
CC
No, original stalk.
------ Follow up post added April 18th, 2016 10:41 PM ------
I'm pretty sure my horn worked fine before the conversion. I only remember removing one wire like yours. It attaches via a bracket with two studs to the front panel.
Old April 19th, 2016, 01:47 AM
Ignotus
gene
1960 109, w/200TDI
Your horn could have frozen up from disuse. Is there a screw anywhere on the housing? Keeping track of where you start turn it in and back it out to free up the diaphragm. The other thing I noticed in your pic it appears the wire might have been connected to the closer stud on the housing which as someone pointed out might be missing a terminal. Lastly if you are not getting power to the purple/black wire the problem is upstream of the terminal. Perhaps the other end is not connected?
Gene
1960 109
1960 88 Ignotus
Blog;
Old April 19th, 2016, 10:51 AM
No, original stalk.
i'd say put 12v manually on the horn using a jumper cable while grounding the case, and see if it honks. if it honks, then the horn is ok and the problem is somewhere else. if it doesnt honk, time for a new horn.
Old April 19th, 2016, 10:12 PM
LakeLBJ
CC
Well thar she blows my friends. I hooked it up directly to the battery with jumper cables and got a nice spark shower and a loud honk. Remounted in the truck and hooked the single wire back up and she is back working fine. And just when I was excited to start using my middle finger more often.
200tdi, horn, tdi
PDWA swap after disc brakes upgrade? jafir Defender Technical Discussions 4 June 8th, 2015 11:16 AM
Won't start after after torrential downpour?! jijalicious Defender Technical Discussions 51 November 10th, 2011 12:17 PM
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
horn not working whitelandy33 Defender Technical Discussions 7 June 21st, 2008 04:55 PM
Fan blower switch not working draaronr Defender Technical Discussions 3 August 24th, 2004 11:26 AM
