horn not working - Defender Source
Old June 20th, 2008, 12:07 AM
whitelandy33
Pecos
hyundai
horn not working
When I push the stick in....no sound comes out.
Checked the dash/main fuses that are tied to horn. They are fine.
Is the horn located in the front right of engine bay? If so, i think eveything is connected. I guess the horn could go bad.
Any other ideas?
I did not see anything in the FAQs or previous posts.
Old June 20th, 2008, 02:42 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
horns do go bad. both tones on mine died. cheap and easy to replace. front right of the engine bay. couple bolts, some plug and you're ready to play.
because six cylinders will take us farther than any president
Old June 20th, 2008, 08:56 AM
NashvilleRover's Avatar
NashvilleRover
Dendy Jarrett
2009 LR3- Well Built
Want them to get out of your way? Try the Hella Super Horns (plug and play) available through Expedition Exchange (www.expeditionexchange.com)
They are relatively inexpensive as well.
Can you say L O U D!!
Dendy
Old June 20th, 2008, 09:02 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
I have a set of year old hella replacement horns available (6 months of which the truck was in winter storage). $20 including shipping. I replaced mine with the supertones since drivers suck in Boston. These are a direct replacement.
ID:	13919   Click image for larger version
Old June 20th, 2008, 10:20 AM
whitelandy33
Pecos
hyundai
I picked up a high and low horn from autozone this morning. Installed one of them and the horn still does not work.
Could it be the switch inside the steering column? I guess I should put a volt meter on the wires that connect to the horn and see if there is power.
Old June 20th, 2008, 11:40 AM
Stmpede's Avatar
Stmpede
Andrew Najarian
'93 NAS D110 #43
that would be my guess. Those switches are pretty flaky.
Old June 20th, 2008, 12:19 PM
whitelandy33
Pecos
hyundai
100 bucks. http://www.roverparts.com/Parts/PRC3875.cfm
It would be cheaper to buy a couple handheld air horns but that would not pass inspection. Any other sources?
Is this an easy install?
Old June 21st, 2008, 04:55 PM
Chaucer
Will
93 110 | 97 90
I wouldn't just go buy parts and swap them out...you should diagnose the issue by tracing the wire connections.
Does power get to both sides of the fuse?
Is power at the switch (before pushing it in)?
After pushing it in, does power get to the horn?
Check grounds also, I think each horn has it's own ground...
horn
Speedometer not working mgrgpg Defender Technical Discussions 4 June 11th, 2009 07:27 PM
louder horn advice chirider Misc. Chit-Chat 9 April 8th, 2008 04:49 PM
My headlights are not working woldd90 Defender Technical Discussions 13 December 2nd, 2005 10:49 AM
'95 Factory Radio Fade/Treble/Bass Button Not Working gamberik Defender Technical Discussions 1 March 30th, 2005 01:05 PM
Fuses? Horn and clock... OCD90 Defender Technical Discussions 3 November 17th, 2003 06:05 PM
