horizontal bars/ aka snap rails - Defender Source
Old September 24th, 2012, 02:31 PM
SBrick
Scott Brick
1995/d90
Please help! I just got my badger II top and am struggling with the horizontal bars/snap rail installation. It seems from the windshield back to the roll cage the snap rail Chris from badger supplied is too long by about 2 inches. I know the windshield may give that much but the badger top is so tight I'll never be able to get it to stretch back to the back of the tub. It does not appear that these horizontal bars can be trimmed etc. Do they come in different sizes, am I missing something? Everything else on the install so far has been pretty easy. Thanks all.
Sbrick
Old September 24th, 2012, 02:44 PM
James Pierce's Avatar
James Pierce
James Pierce Jr.
All the rails were the same. Post a pic of how you have them installed. Something isn't adding up.
Chris' tops are tight.
Old September 24th, 2012, 02:46 PM
Pictures pictures pictures. The little nubs (picture 1) go INTO the slots in the B pillar (the roll bar that goes above your heads behind the driver and passenger seats), then the studs on the other side (picture 2) should line up with the alloted holes in your windshield bracket mount.
Aside from that, you should be referencing the soft top installation guide:
http://www.defendersource.com/tech/d90top.pdf
ID:	58011   Click image for larger version
Old September 24th, 2012, 02:59 PM
aaaaaand he logged off.
Old September 24th, 2012, 03:12 PM
James Pierce
James Pierce Jr.
You scared him off.
Old September 24th, 2012, 03:14 PM
SBrick
Scott Brick
1995/d90
Yeah something doesn't add up. I will have to go home today after work and take everything off and maybe start with the horizontal bars, that right now is the last step and will see if that changes anything. Thanks for your help.
sbrick
Old September 24th, 2012, 03:22 PM
Have you installed any of the defender 90 soft tops before this one?
Your snap rail poles are actually installed and bolted into the windshield frame bracket or you haven't even gotten that far?
I just want to make sure that it's not the top you're installing incorrectly. At the winshield you should take your top and fold the front lip under (this is what sleeves into the header bar) and into the header bar, then continue with the rest of the top. The snaps on your Badger top above your front doors should then line up with the snaps on your horizontal bar if both have been installed correctly.
Old September 24th, 2012, 03:26 PM
SBrick
Scott Brick
1995/d90
I had a hard top installed when I bought the truck. I removed that for the summer and now that it is getting cooler I wanted to make sure I had everything and could install before winter comes around. From what I have read it seems as though the soft top by badger gives the fiberglass top a run for its money as far as warmth, leak etc.. An since it is not my primary car the hardtop probably wont get much more use.
Old September 24th, 2012, 03:34 PM
OK so if you have sourced all of your parts correctly beforehand you should have the following:
A Header Bar - goes above the windshiled and bolts into the windshield frame
Horizontal 5 snap bars
Vertical Rods that attach to the horizontal bars
Alpine Bow
Tailgate Clips
Tailgate Bar
Belt Rails - along tub of truck - for any trucks utilizing a Badger top or 1995-97 trucks, or 1994s not utlizing tops that snap in.
Brand New D90 Soft Top Horizontal Bars (aka snap rails) SeattleRRC For Sale - Parts 5 June 2nd, 2012 08:37 AM
How much are the five snap horizontal bars worth? Birdman Misc. Chit-Chat 0 June 19th, 2011 11:18 PM
Bestop - rough - $500 with rail and 5 snap bars 2yellowlabs For Sale - Parts 2 January 24th, 2011 12:11 AM
ST Windshield retainer bar and horiz 5 snap bars 2yellowlabs For Sale - Parts 0 January 9th, 2011 08:37 PM
5 snap door bars and header bar to mount soft top evilfij Wanted 1 December 3rd, 2005 01:00 AM
