hooking a LT77 up to a 300tdi - Defender Source
Old January 2nd, 2011, 11:39 AM
grbec22's Avatar
grbec22
Roger Ramjet
1985 "90" no defender's back then.
I know it is possible. Is it a much better route to just source a r380 or can this be done easily?
Old January 3rd, 2011, 01:41 PM
mikeslandrover's Avatar
mikeslandrover
Mike Hammond
What have you got under there already? They're different lengths and the 300tdi is mounted in a different location to the 200tdi so you get into prop-shaft length issues.
Mike Hammond
Old January 3rd, 2011, 01:47 PM
the clutch covers are different. If you swap the 200 tdi clutch cover to the 300/r380 one then the r380 will bolt right up to the 200 and vice versa. The clutch cover is the aluminum bit the bolts to the rear of the block that the bell housing in turn bolts to.
Old January 3rd, 2011, 02:57 PM
grbec22's Avatar
grbec22
Roger Ramjet
I'm probably going to bolt scrap the idea and try 300tdi, R380. Really the car should be a five speed. It was never intended to be an auto when it was all started.
Old January 3rd, 2011, 03:38 PM
you have a 300 tdi auto 90 ?
Old January 3rd, 2011, 03:41 PM
diesel_jim's Avatar
diesel_jim
Jamie Austin
This link will tell you everything you need to know <----
300tdi, tdi
NAS D90 300tdi exhaust? Chris Cox Defender Technical Discussions 19 June 13th, 2006 04:59 PM
300Tdi wings/ radiator finisher (defender) Lyman Wanted 2 March 8th, 2006 05:51 AM
Lt77 TexasD-90 Defender Technical Discussions 4 November 8th, 2005 04:39 PM
1995 Discovery 300TDI, Trail Ready.... Joe B For Sale - Vehicles 1 June 23rd, 2004 06:26 PM
