Hood Release Issues - Defender Source
Old December 12th, 2012, 09:32 PM
OahuDefender
Jason
1994 D-90
Hood Release Issues
Hello, I'm having hood release cable issues. The issue is that the cable has broken, several times. It originally broke inside the cab, and I would just reach under the grill and pull down on the cable to open it. Unfortunately, the cable has broken at the latch now so I have nothing else to grab onto. Yes, I know it's my own fault for being lazy and not properly fixing the problem, but when you live in Hawaii and the surf is good you've gotta have priorities.
Anyway, I'd appreciate any help anyone could offer for getting the bonnet open because I've got a bit of work I need to accomplish in there. Thanks for the help and Aloha.
Old December 12th, 2012, 10:01 PM
Take the grill off
Old December 12th, 2012, 10:44 PM
owen's Avatar
owen
Owen Jones
Yellow`95 D90 ST #2188
And when its open, tie a loop of electrical wire to the latch and out of the passenger side of the grille as a backup. Actually it will probably get more use than the one inside!
Dont blame yourself, its your Defender's sense of humor.
"I think you need a little weatherstripping - right here..."
Old December 13th, 2012, 09:37 AM
ron's Avatar
ron
Ron
1994 NAS Defender 90
then put hood pins on
Old December 13th, 2012, 09:43 AM
No dont!
Old December 13th, 2012, 09:48 AM
Bill Larson's Avatar
Bill Larson
Bill Larson
yeah hood pins require a certain overall look! Becareful or it will look too J(Sh)eepish.
Old December 13th, 2012, 10:03 AM
Or install the older manual hood latch that you actuate through the grill
Old December 13th, 2012, 10:26 AM
ron's Avatar
ron
Ron
yes do ... hood pins hardly ever break : )
Old December 13th, 2012, 09:34 PM
OahuDefender
Jason
1994 D-90
Thanks all, I'm definitely going to go one of those routes once I have it open. The problem is getting it open right now. I've taken the grill off but still can't quite get a finger on the latch to trip it. There is not enough cable left to grab. Ideas??
Old December 14th, 2012, 12:36 AM
SonnyAK's Avatar
SonnyAK
Sonny
1993 NAS 110
See if you can find a pair of needle nose pliars w/the 90 degree bend near the end...they should easily be able to reach up and grap the latch arm where the cable attaches, if you have the grill off...
Have someone put downward pressure on the Hood while trying to release it too...It will make releasing the latch easier. I had the same issue once, but my cable was still attached, so I was able to use pliars on the cable to pull the release.
Old December 14th, 2012, 07:45 PM
red64chevelle
Daniel Smith
86 110 300TDI,16 Disco Sport
I searched for the p/n for this and could not find it. I would like to install it on mine to get rid of the cable. Do you have it?
Old December 14th, 2012, 07:56 PM
If this is for a NAS truck then you will have to some modification to the slam panel.
This is not to be taken lightly as there are many different versions over the years.
http://www.defendersource.com/forum/...ead.php?t=3667
hood
hood release joeoftherock Defender Technical Discussions 19 December 15th, 2012 06:47 AM
Hood release cable snapped. willr Defender Technical Discussions 3 April 2nd, 2011 04:24 PM
Hood Release Broke AGAIN! The Wizard Defender Technical Discussions 17 March 15th, 2009 02:34 PM
Hood release help Seanh Defender Technical Discussions 13 February 17th, 2006 01:17 AM
Needed: Hood Release Cable NAS D90 Hans Wanted 4 August 6th, 2005 03:18 PM
