Hood release help - Defender Source
Old February 16th, 2006, 12:00 AM
Seanh
Sean Hanagan
94 D90 ST #910 Matilda
Hood release help
I did a search and folks mentioned puttting the hand inside the grill and releasing it that way. Could someone be more specific about where the cable and release are. I've poked around a bunch but can't find it. I don't want to pull on the wrong place. I need to get in ther ASAP (washer fluid is empty and it's snowing). The mechanic I took it to last destroyed my cable and T handle by crushing the outer housing . Thanks for the help!
Old February 16th, 2006, 12:10 AM
Abrooks's Avatar
Abrooks
Tony Brooks
when looking at the front of the truck, you should be able to reach in between the top 2 slats of the grill, and reach up and you'll feel the cable. Pull it down sharply. Then put either hood pins or quick release latches on it.
Old February 16th, 2006, 12:14 AM
Seanh
Sean Hanagan
Thanks Anthony, Ill give it a go in the am.
Old February 16th, 2006, 12:32 AM
Hans's Avatar
Hans
Hans Haase
The D-90.com Lab Rat
At the worst case, you can always remove the grill from the outside and this will give you much more room to work. The latch is just to the left of center. Replacing the cable and T-handle is quick and easy when you get a new one.
-Hans
My oil line fix
My 100k stopped odometer fix
Old February 16th, 2006, 01:26 AM
oldscratchggf's Avatar
oldscratchggf
nate
95 d90
Hint: hood pins. They are wonderful.
Old February 16th, 2006, 11:47 AM
TDI Guy's Avatar
TDI Guy
2015 LR4
like said above, just unscrew the grill... its right there
Legend in My Own Mind.
Old February 16th, 2006, 02:01 PM
Seanh
Sean Hanagan
I went out this morning and could feel the toggle that you move once the hood is unlatched but I couldn't feel the cable. I was fishing on the right side though. I'll play with the left side and if all else fails I'll pull the grill. There is no doubt that hood pins are next. Thanks,
Old February 16th, 2006, 05:20 PM
pcarey's Avatar
pcarey
Peter Carey
'93 NAS Defender 110 #322
Two things:
Sean, is ANY of the cable still visible in the cab? I had the same issue and by passed the T handle and pulled the cable itself. Was still stuck so I got some locking pliers and it freed up. After that I can pull on the extra loop of cable and bypass the T.
Hood pins. Does anyone have photos of pins being used on a Defender? I'm thinking of going this route and want to see the look first since I know it gets tight to mount them well.
pwc
Old February 16th, 2006, 06:14 PM
flippedrover's Avatar
flippedrover
Tyler
'94 D-90
I'll have to look and see if I have any pics. But I have the camel trophy style pins. Picked them up at a local racing shop.
Jimmy Buffett
Old February 16th, 2006, 08:51 PM
Seanh
Sean Hanagan
I think Yousef has them
Old February 16th, 2006, 08:55 PM
pcarey's Avatar
pcarey
Peter Carey
I got some pictures from Yousef a while back and was just looking for others that might have them. should have mentioned that.
pwc
Old February 16th, 2006, 09:30 PM
Abrooks's Avatar
Abrooks
Tony Brooks
Here are a couple of (crappy) photos of the military latches that I put on my truck. Got 'em from RN.
Old February 17th, 2006, 01:06 AM
oldscratchggf
nate
95 d90
Peter- Any chance you could post the pics you got from Yousef?
Old February 17th, 2006, 01:17 AM
pcarey's Avatar
pcarey
Peter Carey
I take back what I said, I found the PM from Yousef and he couldn't find his and only Anthony's were posted, like you see above.
I did see some some place of a Defender with them on and I'lll keep kicking my head until something falls out.
pwc
hood
Spare tire hood mount bd90 Defender Technical Discussions 15 November 12th, 2017 11:36 AM
hood release joeoftherock Defender Technical Discussions 19 December 15th, 2012 06:47 AM
Hood Release Broke AGAIN! The Wizard Defender Technical Discussions 17 March 15th, 2009 02:34 PM
bonnet / hood alignment jcasteel Defender Technical Discussions 5 December 28th, 2005 12:54 PM
Needed: Hood Release Cable NAS D90 Hans Wanted 4 August 6th, 2005 03:18 PM
