Hood Release Broke AGAIN! - Defender Source
Old October 13th, 2006, 08:14 AM
The Wizard's Avatar
The Wizard
Douglas Wozny
1994/ Defender 90 #500
This is to forth time in the eight years I have owned my '94 D-90 that the hood release cable has failed. My first question is "How do you open the hood with the hood release cable broken?" Second is this part known as a part that fails on a regular bases? Third, is there a better replacement for this system?
The Wizard
To paraphase "Oddball" (Donald Sutlerland, "Kelly's Heros", 1970) "I only drive 'em, I don't know how to fix them."
1994 Defender 90 No. 500
Old October 13th, 2006, 08:20 AM
dmarchand's Avatar
dmarchand
David Marchand
'97 D90 SW Arles
You should be able to either reach up through the grille or remove the plastic panel and release the hood mechanism manually. this does happen often. I've been through 3 in 5 years. Only replacement option you have is install hood pins. Although I'm not a fan.
Could be worse, your accelerator cable could snap like mine did last weekend 3 hours from home. Thanks to vice grips and duct tape, I made it home no problem. But it made me sweat it for a minute. Now I carry a spare accelerator cable.
Old October 13th, 2006, 09:18 AM
You can get a Euro one from George at RDS - it has to be relocated from stock, but it doesnt suck. Run a search on this site and you'll find a number of references including mine. Its not expensite and it works well.
Old October 13th, 2006, 09:43 AM
ECR's Avatar
ECR
East Coast Rover Co.
Just Defenders, nothing else.
Before you install another new one, remove the cable from the sleeve and lube the entire length. This will keep them going for a long time without having to make any changes. They are only 10 bucks.
Email:
Old October 13th, 2006, 11:12 AM
roverboy's Avatar
roverboy
Thomas
Booger
hood pins. www.wildhorses4x4.com
"There is absolutely no excuse for the way I'm about to act."
Old August 25th, 2007, 06:12 PM
Billakris's Avatar
Billakris
Kris
Alpine White 95 Soft Top
So my hood cable broke too. I was just wondering if the factory way of routing the cable was to attach it to the clip for the air filter trumpet.
If this isnt factory, could someone please take a picture of the correct way to route the cable?
Kris
Old August 25th, 2007, 10:02 PM
tkavan01's Avatar
tkavan01
Trevor K
94 d90 #1304
mine broke around xmass, i just attached a stainless steel cable to the lever and stuck it out the plastic grill, now i don't have to worry about it breaking.
Old August 26th, 2007, 01:54 PM
landrovered's Avatar
landrovered
S. Smith
72 Series III 109 Diesel
I used a bit of coat hanger, twisted it around the cable next to the latch. I put a small right angle after I fished it through the grill. If you didn't know it was there you would never see it.
Works great...
Zero dollars.
Old August 26th, 2007, 05:23 PM
rgrrvr's Avatar
rgrrvr
DJ Menasco is The Dude
1995 D90
http://www.deftracing.com/aerocatch_hood_pins/index.htm
http://www.cardomain.com/shoptype/Hood+Pins
http://www.amazon.com/exec/obidos/se...rocess=default
Old March 13th, 2009, 09:48 PM
D90Overkill's Avatar
D90Overkill
David Frank
1995 ST #2615
Lube a new Hood Release Cable with ???
I am about to install a new Hood Release Cable and read a helpful post by ECR to pull the new SS cable out of its sheath and lube it up. This should help it last longer and I'm all for that! But what do you all suggest I use for lube? "Probably not the stuff in my bedside drawer!" Thanks for any insights!
-Dave
Old March 14th, 2009, 01:50 AM
pendy's Avatar
pendy
jim pendleton
89'd90
Petroleum jelly would be good. And it may be close at 'hand'
legend in my own mind
Old March 14th, 2009, 09:39 AM
LOL. Yes this must be common. Mine broke, then the replacement's handle broke and now needs to be pulled way far out to activate. This thread reminded me I have a replacement waiting to be put on!
Thanks for the suggestion to grease the cable, and I think I'll install a backup wire this time while I'm in there. Then I'll order a euro spec one for when this fails - the hand latch on Janey (which I assume is the euro spec) rocks!
charles
Old March 14th, 2009, 10:12 AM
the early one is a hell of a lot better design than the cable ones and is easily retrofitted
Old March 14th, 2009, 11:19 PM
bjf's Avatar
bjf
barry f
94 ST #395
Can you replace just the handle? Mine work fine but the handle cracked and fell off
Old March 15th, 2009, 02:54 AM
budz
sal gorriceta
various rovers
I used Amsoil synthetic waterproof grease to all my trucks...
Old March 15th, 2009, 12:55 PM
Retrofit's Avatar
Retrofit
Pat
1984 110 CrewCab 200Tdi
AMEN to that !
Pat
Kirk Lazarus, Tropic Thunder
Old March 15th, 2009, 02:24 PM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
I *think* I have the early one somewhere that I can send to whoever if they want it. Just pay $10 for my time and shipping. But, hood pins are better, and if done right, look really good too.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old March 15th, 2009, 02:34 PM
Don't think so.
Buck you have email,
charles
hood
Spare tire hood mount bd90 Defender Technical Discussions 15 November 12th, 2017 11:36 AM
hood release joeoftherock Defender Technical Discussions 19 December 15th, 2012 06:47 AM
Hood release help Seanh Defender Technical Discussions 13 February 17th, 2006 01:17 AM
bonnet / hood alignment jcasteel Defender Technical Discussions 5 December 28th, 2005 12:54 PM
Needed: Hood Release Cable NAS D90 Hans Wanted 4 August 6th, 2005 03:18 PM
