Hood Release - Defender Source
Old November 3rd, 2010, 10:24 AM
97-D90-736
Nick Vogel
1997 D-90 / 2012 LR4
Hood Release
So the left tab on my hood relase cable broke last night. A new one isnt that expensive, but was thinking about ditching that all together and good with the hood latches. Has Anyone made the switch? What are the cons, besides the obvious that the hood would not be locked?
Old November 3rd, 2010, 01:22 PM
EWR's Avatar
EWR
Carey
1954 CJ-3B
Your 90 would look like a Jeep.
What tree?
Old November 3rd, 2010, 04:58 PM
FlaD90's Avatar
FlaD90
Tom
1994 ST D90
Hood latches come in handy when trail riding to keep things good and tidy, if you dont off road much then really not needed.
Old November 3rd, 2010, 05:07 PM
97-D90-736
Nick Vogel
Yes, it might look like a Jeep but the hood cable is PITA.
Went ahead and ordered a new one from AB. Only 14 bucks.
Old November 4th, 2010, 12:04 AM
The idea of drilling holes in a perfectly good hood to install latches frightens me.
I would switch to an early 90/110 manual release first. You can either install it with or without the lock on the grille.
Old November 4th, 2010, 12:36 AM
D90user's Avatar
D90user
steve
109/110 ambulance-55 series I
I switched to the cable with the lever, not the pull and it has never given me problems since.
I run series latches as well, but it is more fore piece of mind with a tire on the hood.
Old November 4th, 2010, 01:45 AM
Buckon37s's Avatar
Buckon37s
Buck
Re-Fendered 90
Hood pins are tits. Good upgrade.
2009 King of the Hammers
BUCK Wild Racing
Driver: Me
Co-driver: Pat Quirk
Team 911
Rover Tracks
PSC
DJ Safety
West Coast Rovers
Reel Driveline
Old November 4th, 2010, 08:27 AM
Weldon's Avatar
Weldon
Weldon Pundt
"95" D-90
Jim, do you have a part number for this early 90/110 manual release and/or a location for ordering?
Weldon
Old November 4th, 2010, 09:18 AM
If I was looking for one I'd call George at RDS - you need a new slam panel. I'm guessing there is someone that has updated a 1984/85 truck around here that you could get the parts from.
I prefer the TD5-style hood release, which mounts on the passenger side of the tunnel and works much better.
Old November 4th, 2010, 05:18 PM
D90user's Avatar
D90user
steve
That is the one I'm talking about. George has them.
Old November 11th, 2010, 11:49 AM
97-D90-736
Nick Vogel
I have a new cable. Can someone give some pointers on changing this out?
Old November 11th, 2010, 08:44 PM
There are only 3 points that you need to pay attention to.
1. A small bolt pins the cable to the latch itself. With the hood open, you can see it to the left of the latch. You'll need to loosen that off
2. The cable sheath is held to the radiator panel by a small clip which you'll need to slip off the radiator panel. This one is best done from the front of the truck after removing the black plastic grill.
3. Where the cable goes through the bulkhead there is a lock nut on the engine bay side you need to undo. Once undone you can pull the whole cable assembly out into the cabin.
Installation is the reverse of removal
hth
charles
hood
hood release joeoftherock Defender Technical Discussions 19 December 15th, 2012 06:47 AM
Hood Release Broke AGAIN! The Wizard Defender Technical Discussions 17 March 15th, 2009 02:34 PM
Hood release help Seanh Defender Technical Discussions 13 February 17th, 2006 01:17 AM
bonnet / hood alignment jcasteel Defender Technical Discussions 5 December 28th, 2005 12:54 PM
Needed: Hood Release Cable NAS D90 Hans Wanted 4 August 6th, 2005 03:18 PM
