Hood rattle - Defender Source
Old February 5th, 2016, 12:13 AM
IvanKV's Avatar
IvanKV
Ivan
'89 110 County - 200TDi
Hood rattle
I am having an insane hood rattle. It visible warps and slams around, it broke off the hood prop and is the loudest part of the truck. It is only on idle and stops with the smallest amount of weight(putting my hand on it will stop it). Any thoughts on a solution? I recently took the hood off to repair the radiator, could I have improperly seated it?
Bonus working on the 110 picture
Old February 5th, 2016, 12:20 AM
Do you have the plastic pieces that go between the bonnet hinge half and the bulkhead hinge half?
Old February 5th, 2016, 12:23 AM
Davis's Avatar
Davis
Chris Davis
94 NAS D90 6.2LS
Are you using the rubber stabilizers atthefront left/right? They extend/retract by screwing them in or out. Sounds like you are balancing between hood pin (which also screws in/out as well) and one of the hinges at bulkhead. cbeck the bulkhead hinges and make sure plastic inserts are in place and that one of them isn't separated from bulkhead. Next make sure front pin is low enough and/or lower it. Look at contact point of rubber pubs at front left/right and adjust those, too, if need be...
------ Follow up post added February 4th, 2016 10:24 PM ------
Yeah, those ^^^^^^^
Old February 5th, 2016, 07:07 AM
Is it possible that the engine itself is hitting the bonnet?
hood, rattle
Hood Tire Carrier/Hood Protector/Light Bar CDeWan Wanted 2 June 15th, 2011 09:39 AM
Puma Hood and Hood support CDeWan Defender Technical Discussions 1 June 9th, 2011 11:51 AM
Feeler: Defender hood (bonnet) with hood pins? Buckon37s For Sale - Parts 7 July 10th, 2010 05:18 PM
WTB/WTT White Bonnet / Hood for RN hood tire kit woldd90 Wanted 7 January 15th, 2008 11:49 AM
SW Rear Door Rattle seattlejanzen Defender Technical Discussions 5 November 5th, 2003 10:25 AM
